Pages: 1 2 [3]  All   Go Down
Author Topic: Chasing loudspeaker-level Crosstalk  (Read 6194 times)
Hayden J. Nebus
  • Richmond, VA
Re: Chasing loudspeaker-level Crosstalkt
« Reply #20 on: February 13, 2015, 09:54:22 am »
tens of kOhm is effectively open circuit for speaker impedance loads.
If the signals are clean at the amp, and crosstalk occurs at the speaker end, it must be something. I ASSUme speaker grounds are similarly tens of K impedance separated?
Speaker grounds are 100+kohm to each other
« Reply #21 on: February 13, 2015, 10:07:18 am »
If I understand your measurements that means the grounds are not common so crosstalk should not be from that path.
Troubleshooting involves divide and conquer. so how about removing another variable.
Connect one side amp to speaker. Connect the other pair of wires to other speaker. At the amp end of that other pair shirt the two wires to each other but do not connect them to the amp.
Does the crosstalk go away... If not the wires are the guilty playa...
Hayden J. Nebus
  • Richmond, VA
« Reply #22 on: February 14, 2015, 10:01:05 am »
I'm 99.9% convinced the cabling is at fault, but will short one side (not the amp!) Monday and have a look.
« Reply #23 on: February 14, 2015, 11:29:48 am »
While it seems unlikely (to me), if speaker level current is being induced into the wires, shorting them at the amp end will replicate the low output impedance of the amp but completely without any possible amp signal, This will prove that it isn't crosstalk inside the amp but being induced into the wiring.
Good luck
Pages: 1 2 [3]  All   Go Up
Page created in 0.12 seconds with 24 queries.
