Author Topic: I-Nuke NU4-6000 not per website  (Read 16587 times)
Jens Droessler
Re: I-Nuke NU4-6000 not per website
« Reply #30 on: February 11, 2015, 05:52:11 pm »
Yes, the manual I received says, in Mono mode with crossover engaged, to use Channel B's 2+ and 2- poles for LF.
BUT, I have yet to find a signal there.....it's on B's 1+ and 1-
Hey, at least it's LF  :)
I think you missunderstood what they meant. The output signal from channel B will be on 2+/- of the speakon output of channel A. They could have formulated that better. It means you can put a 4wire speakon cable to channel A or C and have ch A/C on 1+/- and ch B/D on 2+/-.
Luke Geis
« Reply #31 on: February 11, 2015, 07:57:22 pm »
Thx Luke, yep, but I guess that would leave the subs pretty under powered..
I've decided to just give in and use an old x-over.... x-over HP to stereo  A & B mains, x-over LP to C&D in either mono or bridge...
Disappointing not to have an all-in-one solution as potentially available from online documentation....but the dang amp still represents the cheapest way I can find to power the old boxes...
Well if the tops are what I think they are in ohms, the subs will actually pair up well. In theory there will almost twice the wattage for the subs which should be at 4 ohm's.  Also running it that way you have the ability now to turn the tops down a little to match the subs if need be. It's an option that in theory should provide better results than the basic method currently used.
Mark Wilkinson
« Reply #32 on: February 11, 2015, 09:00:02 pm »
Jens, yes, you are correct as stated. Thanks, I did miss what they meant.
As you say, the output from Channel B is on speakon 2+/- of output channel A if you want to 4-wire it.
And as I found, it is also on output B 1+/-
So either way, I guess nothing changes from the available output combinations, other than being able to run 4 wire speakons, or 2 wire ones.
Mark Wilkinson
« Reply #33 on: February 11, 2015, 09:21:27 pm »
The S115IV tops, and SW118IV subs (2), are all 8 ohm boxes.  Tops and subs have same wattage specs; noise 250, program 500, max 1000.  Tops are 99db 1w, subs 96.
So I'm thinking that level power to all leaves me at least 3 db short on the subs...and probably more like 6-9db short, given the usual sub boost bias...
It's why I thought this amp would be perfect if I could high pass two channels in stereo, and low pass two channels bridged into parallel subs. (with maybe a little cut to the subs)
I'm still going this route I guess, but with an external x-over.......unless I'm missing something????
Thx again. Mark
« Reply #34 on: February 12, 2015, 02:49:27 am »
That would make it a Beechcraft, not a Behringer...
Tim, you are tough man.  Indeed I am used to typing the aircraft type rather than the proper word barren.  Rather than try and use big words I should have just said that the construction sucks and the stuff that's now wave soldered looks like they used the solder blob/bomb method.  Honestly I think the Kenwood Class D amp I have in my truck is beefier that the inside of the iNuke's.  Compared to the brick shit house EP series from Behringer it was a shock.  Say what you will but the EP's are very usable but heavy amplifiers.  Used within limits they get the job done.  With the iNuke stuff it just looks like a fan failure or an undetected fault would cause the amp to meltdown.
One of the things I learned in the last year, especially from listening to the big iron drivers like yourself Tim is you have to count on your gear.  When I would role a Behringer EP amp in I always would have a spare in the truck and a reluctance to use them to capability that they just could not take it.  With the Crown XTI, QSC, B&M drivers and Sennheiser Wireless I use today I have confidence.  Sure things can still break but I haven't been let down yet.
The difference between flying a Baron or a Cherokee!
Lyle Williams
« Reply #35 on: February 12, 2015, 03:17:07 am »
So you need to be bridged into the subs?  Stereo left into input A, stereo right into input C, switches to mono+crossed.
Output A gives you left tops, output B gives you left sub, output C gives you right tops, output D gives you right sub.
Uses all of your speakers, is stereo, relative sub/tops level is controllable, and it will be way louder than you can run in the appartment.
Mike Caldwell
  • Covington, Ohio
« Reply #36 on: February 12, 2015, 09:09:30 am »
Don't worry I got your joke and laughed! Things will really be scary if Behringer starts up an aircraft division.
Mark Wilkinson
« Reply #37 on: February 12, 2015, 09:59:59 am »
Thanks Lyle.  How does this give control of relative sub/tops level?  In mono mode, level for A & B is controlled solely by A pot,  C & D by C pot.
This is the config I'd decided to try first, hoping relative balance is close enough for low shelving eq to suit to taste.
And sure, for apt use I get about anything works .... but I have told my son he is welcome to play with the rig here and there, outside included. So looking for all the available sub there is....
Lyle Williams
« Reply #38 on: February 12, 2015, 10:50:14 am »
Ok, I see the problem now.  Yep, that seems to be a dumbass design decision.
Especially as they had this sorted out properly in their earlier amp designs.
« Last Edit: February 12, 2015, 10:55:19 am by Lyle Williams »
Luke Geis
« Reply #39 on: February 12, 2015, 04:40:19 pm »
Thx again. Mark
Well sort of...... The general rule is 2x the power to the subs as to the tops. If you run the tops at 8 ohms you would have X watts. Now the subs would be ran in parallel, which is a 4 ohm load. This should nearly double the watts supplied to them. Now you could bridge mono the last two channels which would give you about 5x the power. However I do not think you could utilize the X over with the last 2 channels in bridge mode? The literature seems to present that it can? Based on what you say it will not.
Here goes:
1. Run channel A & B as a basic stereo setup. No there will not be a low pass, but there could be worse things, plus you really could use one anyway.
2. Run channel C & D in mono with the crossover engaged and run the subs out of the appropriate output. This will yield nearly twice the power or about a 3db boost. Not as much boost as many would like, but you can turn the tops down 3db to acquire a 6db difference.
3. Test and see if in bridge mode for C & D that the X-over function still works? If it does this will yield 5X the power to the subs.
4. get a X-over that will allow 3 inputs ( L, R, and mono/subs ) then set it up for your speaker config of L & R with mono subs. Now set the amp up to run A & B in stereo and C & D in bridge mono. Left and Right to A & B and subs to the appropriate +/- output terminals on the C & D outputs. This is the best option and will yield the best results all around.
Pages: 1 2 3 [4] 5 6   Go Up
Page created in 0.054 seconds with 22 queries.
