Author Topic: Clear-Com Help  (Read 2757 times)
William Schnake
    • Schnake Sound & Light
Clear-Com Help
« on: January 18, 2015, 09:13:36 pm »
We seem to be getting several larger shows than usual this year, which means that we will be hiring in more and more lighting.  I have a friend who will rent me a Clear-Com setup for $100 per show, not bad.  However, this year I have at least 12 shows that I will need to have some kind of communications for.  I am thinking purchase rather than rent and then I have a system I can use and can rent.
My requirements are that I can have two separate channels working on a base station.  We are going to be doing several shows that will have an LD as well as two spot operators.  I think that should be one channel set.  Additionally, I would like to be able to use a second channel to call audio from FOH to the stage.  I have been doing some checking on the web and it looks like I could get a Clear-Com MS-702 base station and then three or four RS-701 remote stations.
I know absolutely nothing about the Clear-Com systems except how to plug them in and turn them on.  So I am wondering if this type of system make sense to purchase and if I am on the right track.  Any constructive suggestions are welcome.  ;)
Thanks
Bill  8)
Bill Schnake - Owner Schnake Sound & Light
Avid/Crown/EAW/EV/Midas/RCF/Shure/Yamaha
schnakesound.com
Tim Padrick
  • Indianapolis
    • T.P. Audio
Re: Clear-Com Help
« Reply #1 on: January 18, 2015, 09:31:16 pm »
Tom Bourke
    • http://www.cwalv.com
Re: Clear-Com Help
« Reply #2 on: January 18, 2015, 09:41:57 pm »
Craig Hauber
Re: Clear-Com Help
« Reply #3 on: January 19, 2015, 12:01:32 am »
http://prointercomllc.com/products
And just so the OP knows, the Pro Intercom stuff is analog "clear-com" compatible.
"Clear-Com" has almost become a "kleenex" type term that many people use to describe show intercoms.
However you should see what type of system your local customers are currently renting and get something that works with that as many rent to enlarge their existing systems -and many aren't "clear-com" direct compatible (such as Telex or RTS)
For me, it used to be RTS or nothing when it came to complete comm systems for productions, (working with other co's for staging, lights, video and talent IFB) but that was a while ago, I'm sure digital systems have taken over that level of show now.
For sound company (FOH to stage type use) it seemed like "clear-com format" ruled and because of that lots of Production Intercom gear.
Likewise church, school and community theater really used Production Intercom above all others.
Good reliable gear that I'm glad they are back in business.
Craig Hauber
Mondak Sound Design
-Live PA
-Installs
-Theatre
William Schnake
Re: Clear-Com Help
« Reply #4 on: January 20, 2015, 07:48:24 am »
Tim, Tom and Craig, thanks for your responses.  Tim, I think you are in Indiana so I will be reaching out to you via PM.
Thanks
Bill
schnakesound.com
John Penkala
Re: Clear-Com Help
« Reply #5 on: April 14, 2015, 10:13:04 am »
Thanks
Bill  8)
Bill,
      FWIW, A two channel com system with single channel packs is a single channel com system.  If you go two channel, you should go with the RS-703 belt packs. It gives you much more flexibility. However, you'll need at least one TWC-701 to put 2 channels of com on a single 3pin XLR.
JP
Andrew Broughton
    • Check Check One Two
Re: Clear-Com Help
« Reply #6 on: April 14, 2015, 11:50:01 am »
Just don't use the '03 series (2-channels down 1 XLR) if you want compatibility with anything else or want to use call flashers.
Personally, I would not recommend that system.
-Andy
  • Old enough to know better
  • Audio Plumber
Posting Rules
« Reply #7 on: April 14, 2015, 12:07:54 pm »
A little late to reply, I know,
Posting Rules
Page created in 0.045 seconds with 23 queries.
