Author Topic: QSC TouchMix-16  (Read 28202 times)
Don Davis
  • So Cal
Re: QSC TouchMix-16
« Reply #10 on: January 20, 2015, 04:17:42 pm »
Another major problem with the unit is that the dynamics processing occurs immediately following the input, and is therefore always audible in the aux outputs. I mentioned this to a QSC rep who seemed incredulous at first, but then confirmed that this was indeed the case. I heard through the grapevine that this also might be something addressed in a new firmware revision. I hope it is, because compression in the monitors drives most singers nuts.
It looks like the new firmware is out and has addressed some of the issues:
"New features include:
Support for password protected, multi-level security access
Expanded Wi-Fi options (including wired connection to an infrastructure router)
Programability of User Buttons
More options for auxiliary mix pick-off points
Expanded channel presets
Updated iOS app
Personal monitor mix application for both iPhone and iPod Touch
Operator may limit or allow access on a per-device basis
iPhone control of the record/playback transport controls and programmable user buttons
Android support (coming soon)
TouchMix v2.0 software standard on new TouchMix-16 and TouchMix-8 models and available as a free download at QSC.com for existing TouchMix owners."
I plan on talking to the folks at the QSC booth at NAMM before I pull the trigger.
John Roll
Re: QSC TouchMix-16
« Reply #11 on: February 02, 2015, 10:04:02 am »
I have not noticed this on my TM16.  However, Chris Brouelette  posted this on QSC's forum: Firmware V2.0 will be released Jan 22, 2015.
I like my TM16, it works great for Ceremonies & Cocktail bands.  I haven't worked with a Bar Band on it, but at first... it maybe a little slow like any other digital console setting up for the first time.
My only issue with the supplied console is the USB Network thingy, it has a very limited range.  However, that can be easily fixed with a WiFi Network box.
Matt,
What do you mean by limited range? 25'? 30'? 50'?
John
John Roll
JMR Pro Audio
QSC, JBL, Presonus, Audix, K&M, EWI, Furman
John Roll
Re: QSC TouchMix-16
« Reply #12 on: February 02, 2015, 10:07:41 am »
Updated iOS app
Don,
Did you clarify the "more options for aux pick off points"? Does that include "pre everything"?
John
John Roll
JMR Pro Audio
frank kayser
Re: QSC TouchMix-16
« Reply #13 on: February 02, 2015, 04:16:13 pm »
Don,
John
I regularly use the TM16 via the WiFi dongle at 40' with no interruption, despite bring directly beneath a 600mw WiFi access point (12' ceiling mounted).  I was not expecting that performance.
The new menu does have "Pre All", "Pre-Dyn", "Pre-Fader", and "Post Fader" options.
frank
Don Davis
  • So Cal
Re: QSC TouchMix-16
« Reply #14 on: February 02, 2015, 04:38:02 pm »
Don,
John
Sorry, been quite busy, yes as Frank said Pre options are there now.
I have one on its way, can't wait to try it out.
John Roll
Re: QSC TouchMix-16
« Reply #15 on: February 03, 2015, 03:29:39 pm »
frank
Frank, that's great news. After seeing this thread I went to the QSC forum for the Touchmix. There are more than a few posts about lockups and other weirdness that gave me chills. (I just had a lockup with my SL1642 that forced me to send it in for service) What's your experience?
John Roll
JMR Pro Audio
John Roll
Re: QSC TouchMix-16
« Reply #16 on: February 03, 2015, 03:33:59 pm »
BTW,
Someone in the Lounge commented on how it looked like the weight of the snake would pull it off of the surface it sat on. I currently have a copper snake and if I go this route the iPAD would be forthcoming. Will the TM16 handle the weight of the cable?
John
John Roll
JMR Pro Audio
frank kayser
Re: QSC TouchMix-16
« Reply #17 on: February 03, 2015, 04:56:54 pm »
BTW,
John
John,
I have not had any type of lockup in the month we've owned it - I've used it for the in-house gigs at least 15 times.  I may have had a momentary drop in WiFi connection maybe 10 times at most.
The unit is more substantial than it looks - a fair amount of weight - I was actually a bit surprised.
That being said, put enough weight on the connectors, it will tip.
I have it on the top of an "upright" piano, and as long as I keep it 2"  or so from the edge, I do not have a problem with it tipping.  I think if there is any transition from the mixer to the edge, that will take enough cable weight/force vector to be fine.  The feet seem soft enough to grip, and not slip.
The cables I use are not a snake, but individual cables that drop to the stage deck about 4 feet - two mains cables and two aux cables, and at the most so far 12 channels.  The two main cables have a short jumper as the house cables have right angle connectors on them - so there is also the weight of t pairs of connectors unsupported.  If the cables or snake were to have a six or eight foot unsupported drop (vs my four), that would be a problem.
On a regular table, it isn't going anywhere.  I wish I could compare the stability to say, a Mackie 1608, but I can't.
I was very apprehensive of the non-standard power connector - but after seeing it and handling it, I've come away with a pretty good feeling that it is solid, and will not be a problem.  A caution is that the connector is quite tight, and could frustrate someone in a hurry to disconnect - I can guarantee that yanking on the cord will not disconnect the connector.  It feels more robust than a standard IEC connection.
Hope that helps.
frank
David Elthorpe
Re: QSC TouchMix-16
« Reply #18 on: September 24, 2016, 03:07:57 am »
Updated iOS app
Re: QSC TouchMix-16
Page created in 0.041 seconds with 24 queries.
