Pages: [1] 2 3  All   Go Down
Author Topic: Spanset Rigging  (Read 12644 times)
Xavier Moore
Spanset Rigging
« on: January 05, 2015, 12:45:51 pm »
On the pitcures attached its showing how a spanset is wrapped around the array lift forks. on that spanset is it two spansets or one spanset and would someone be able to tell me what the lengths are because im new to vertical array lifting, and i have been doing ground stacking for a while.
i plan on investing in the sumner eventer 16 or 20 and the carvin trx3210a array speakers. the speakers weight 60 lbs ea. and the flybar is probably 20 lbs and im going to only use 4 speakers per side for now.
i was looking at the company spanset and i came across this spanet that they told me comes in different lengths.
http://www.spanset-usa.com/products-services/lifting/roundslings/stage-slingr.html
model: ss90
please help me to under stand how you wrap the spanset around the forks.
Ray Aberle
    • Kelcema Audio
Re: Spanset Rigging
« Reply #1 on: January 05, 2015, 01:00:05 pm »
Have you consulted a rigger?
That's probably a 6' SpanSet in use there, but as your rigger will explain to you, you're going to want to have a variety of supplies (SpanSets of varying lengths, shackles, steel, etc) in your rigging trunk.
Kelcema Audio
Scott Helmke
Re: Spanset Rigging
« Reply #2 on: January 05, 2015, 01:00:31 pm »
1) Please change your profile so that your real name is shown.
2) Hanging from a lift in that manner is not safe - the downward pull on the spanset puts sideways stress on the forks.
Doug Fowler
  • Saint Louis, MO USA
Re: Spanset Rigging
« Reply #3 on: January 05, 2015, 01:09:16 pm »
model: ss90
Read the rules, fix your display name.
Thank you for your cooperation.
Milt Hathaway
    • http://www.fitzcosound.com
Re: Spanset Rigging
« Reply #4 on: January 05, 2015, 04:13:36 pm »
How much?
Milt
FitzCo Sound, Inc.
Midland, TX
Ray Aberle
    • Kelcema Audio
Re: Spanset Rigging
« Reply #5 on: January 05, 2015, 04:24:29 pm »
I was under the impression that the Sumner Eventer lifts were designed for exactly this usage in mind.
Kelcema Audio
Scott Helmke
Re: Spanset Rigging
« Reply #6 on: January 05, 2015, 04:29:20 pm »
How much?
I don't know if the Sumners are OK with side loading. I called Genie a while back and sideways loads on the ST towers are not rated. So instead you'd want something across the forks to provide a center hang point, or maybe just a spacer to keep the forks from being pulled toward each other.
Re: Spanset Rigging
« Reply #7 on: January 05, 2015, 04:48:38 pm »
We use a spacer made from 2.5" square steel tubing.  It's only to keep the forks from being pulled together and is not designed to suspend any load.
Jelmer de Jong
Re: Spanset Rigging
« Reply #8 on: January 05, 2015, 04:57:29 pm »
How much?
That depends on the amount of friction you get by wrapping the spanset around the forks and the angle to the load beneath.
I suggest you take a piece of truss or maybe the special spreader-bar made by the manufacturer.
Another thing to be carefull about is the amount of ballast you put on the base of the lift.
Scott Helmke
Re: Spanset Rigging
« Reply #9 on: January 05, 2015, 05:10:07 pm »
One big issue with the Sumner lifts is that the weight rating drops quite a bit as you move out on the forks with your load. The Genie does this too, but not as much as the Sumner.
Pages: [1] 2 3  All   Go Up
Page created in 0.047 seconds with 23 queries.
