Pages: 1 [2] 3 4 5   Go Down
Author Topic: Removing Tamper-Proof Bolts  (Read 15752 times)
Mike Sokol
Re: Removing Tamper-Proof Bolts
« Reply #10 on: December 24, 2014, 09:13:04 am »
Easy-outs are brittle. If you haven't broken an easy out, you haven't used them much.
Yeah, IIRC it's impossible to drill out a broken Easy Out. We don't have to pull out these brackets until after the holidays, so we'll take tools for all contingencies we can think of, start simple, and keep experimenting until we have success.
Mike Sokol
mike@noshockzone.org
www.NoShockZone.org
Stephen Swaffer
« Reply #11 on: December 24, 2014, 07:43:10 pm »
+1
The "Easy" in the name HAD to come from marketing-certainly not a nickname!
My vote is for the dremel with the grinding disks-if I wanted to save brackets, etc I might try Easy outs, etc-otherwise time is money and grinding the heads off, while it may damage the brackets slightly will get them off.
Steve Swaffer
duane massey
« Reply #12 on: December 25, 2014, 01:24:05 am »
Small grinder with a diamond-cut blade. If you don't need to re-use the brackets this will be the quickest removal, and the blade will last for a long time.
Duane Massey
Houston, Texas
Mike Sokol
« Reply #13 on: December 25, 2014, 09:59:15 am »
My contractor has already recommended the diamond cut blade in a grinder route. We're going to have to cover up everything since there's a pair of antique life-sized statues within a few feet of these brackets. And I don't care if we trash the brackets, we just need to get them off the wall for plastering and painting. I'll be sure to take pictures of this...
Mike Sokol
www.NoShockZone.org
Tim Padrick
  • Indianapolis
    • T.P. Audio
« Reply #14 on: December 27, 2014, 01:20:05 am »
I've never seen that type.  If they break off when removing them, why don't they break off when installing them?
Steve M Smith
  • Isle of Wight - England
« Reply #15 on: December 27, 2014, 06:25:31 am »
That's a very good question!
Steve.
Mike Sokol
« Reply #16 on: December 27, 2014, 08:08:44 am »
When installing them you keep applying torque until the bolt section sheers off, then A) you know that they're tight enough, and B) they're not coming back out easily.
Mike Sokol
www.NoShockZone.org
Steve M Smith
« Reply #17 on: December 27, 2014, 08:39:20 am »
... and a very good answer!
Steve.
Tommy Peel
  • Longview, Texas
« Reply #18 on: December 27, 2014, 12:57:37 pm »
Ease-Outs make me cringe.... I worked in a tractor shop for a couple of years a few years ago and had more experience with those than I care to think about....
Jamin Lynch
  • Corpus Christi, TX.
« Reply #19 on: December 27, 2014, 01:26:00 pm »
Wait, are the heads still on? Surely not. :o
How tight are they? Can you grab the shoulder with a large pair of channel locks or vise grips? Maybe they are loose enough to turn out.
MAGA-Make Audio Great Again
Pages: 1 [2] 3 4 5   Go Up
