Pages: 1 2 [3]  All   Go Down
Author Topic: RF frequency sweep  (Read 9438 times)
Lyle Williams
Re: RF frequency sweep
« Reply #20 on: December 04, 2014, 03:07:11 pm »
I had some minor problems with other test gear from an AM transmitter.  I was getting it at +6dBm out of the coax from the antenna!  But the impact was a fairly subtle and cleaned up with a high pass filter.  But that was +6 directly in the RX input, not -6 onto a four inch wire antenna sitting on the other side of the room.
I just tried adding a mini-circuits bandpass filter (SBP-70) to the dtv stick and the results are still pretty poor inside the filter's passband.
Kent Clasen
« Reply #21 on: December 16, 2014, 09:01:02 am »
Peter,
Thanks.  I have been reading up on the TTi on your recommendation.  I am curious if you can export scans into Workbench?  I would like to not be tied to a computer (PC) with RF Explorer, (their Clearwaves SW looks nice though- is anyone using RF explorer with a Mac/Parallels? how does it compare vs TTi) but have the ability to export to Mac Workbench if possible when needed for more involved coordination situations.
Thanks all..
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
« Reply #22 on: December 16, 2014, 11:10:31 am »
Peter,
Thanks all..
Kent,
I have a TTI PSA2702, and yes, you can import them into WWB6, however not directly.  You do have to go into the .csv file and change the formatting a little bit and remove all the header info.
Audio Systems Design Engineer
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
Chris Johnson [UK]
« Reply #23 on: December 17, 2014, 01:02:58 pm »
Kent,
Yes, I've been meaning to write a script to automate this. Should be pretty straightforward really. Has anyone done this already?
If not, I'll post back!
Riedel Communications
Pages: 1 2 [3]  All   Go Up
Page created in 0.046 seconds with 23 queries.
