Author Topic: Waves Multirack Native Latency Testing video  (Read 12079 times)
Mark Payne
    • http://www.sflgroup.co.uk
« on: November 11, 2014, 02:26:07 am »
Hi
https://www.youtube.com/watch?v=FCyK160EtU4
I did one of my unscripted "one take wonder" training videos using a Midas M32's USB port to directly drive Waves Multirack Native. I use Tuning Capture to measure latency and show the effect of manipulating system settings.
I do plug SFL just a little bit but I hope this is 99.5% tech informative to be allowed :-)
Next I plan to do similar sessions on using Digigrid MGB for dual redundant recording and another on looking at the performance improvements of using full Multirack Soundgrid.
Cheers
Mark
Mark Payne www.sflgroup.co.uk
mark@sflgroup.co.uk
Sound Lighting and Visual Systems
Sales, Hire, Consultancy and Design
Nitin Sidhu
  • New Delhi, India.
Re: Waves Multirack Native Latency Testing video
« Reply #1 on: November 11, 2014, 04:09:35 am »
Hi
Cheers
Mark
That was good Mark!
Looking forward to the Digico and Soundgrid videos.
My RTA is always flat.
Mark Payne
« Reply #2 on: November 11, 2014, 04:28:41 am »
HI Nitin
I will be doing a bunch of Waves Soundgrid stuff but none of it will be with Digico. Its not something I use (much). Midas, Yamaha and Roland here... oh and Avid but I have forgotten how to use that, been a long time.
Watch this space!
I think I need to up the pace on these one takes.....
Agree?
M
That was good Mark!
mark@sflgroup.co.uk
Art Nadelman
« Reply #3 on: November 11, 2014, 12:39:49 pm »
Agree?
No.  I think you pace was excellent as was your presentation.  Very nice!
Art
Mark Payne
« Reply #4 on: November 14, 2014, 12:39:16 pm »
Ok so Part 2 is now up
http://youtu.be/0cs576ul7Kc
This is part 2 of 3. It goes on for ages as I compare the RME Madiface with the Waves Digigrid MGB.
We do Waves Live plugin stuff in Native and Soundgrid mode and measure the xxxx out of everything.
At the end of it I manage to bore myself......!!!!
Mark
Art
mark@sflgroup.co.uk
Marty America
    • Roadie Software, LLC
« Reply #5 on: January 03, 2015, 01:13:56 pm »
Thank you Mark! This is exactly what I was looking for! Well done!
Marty America
Chaska, MN
Jeremy Stark
    • Bergsten Music
« Reply #6 on: January 03, 2015, 11:16:22 pm »
Have any of you tried this with any Dante Setups?
Will using DVS with 4ms latency cause to much added delay on the inserts?
1, 2, 3.... Lift... I mean Coffee.
  • Old enough to know better
  • Audio Plumber
« Reply #7 on: January 03, 2015, 11:53:34 pm »
It depends entirely on what you are doing with the inserts. It is going to be too much latency for channel processing like eq and compression. It will be fine for things like reverb that may already have 10ms of pre-delay built in. But reverbs are probably better done with an aux send and a channel in return.
What console are you thinking of using Dante on inserts with? It is currently not possible with Yamaha console, that do not allow Dante to be used with inserts.
Jeremy Stark
    • Bergsten Music
« Reply #8 on: January 05, 2015, 12:23:33 am »
Currently we have 3 X32's. Two with USB XUF cards, and one with Dante card.
I'll do some testing and see what kind of real world delay difference I am getting between the two different setups.
We also have a CL5, with an Dante-MY16 loaded into one of the slots (Which are patchable in the inserts points)
And, like you said, should be fine for time based effects. And, I Don't really feel like spending the extra dollars to get the WSG-Y16 card.
I am just starting to experiment with multi-rack to see if it will help me with consistency in the long run.
Nitin Sidhu
  • New Delhi, India.
« Reply #9 on: January 05, 2015, 12:38:39 pm »
Hello Again Mark!
Another great video!
And a big thank you and 2015 greetings!
Regarding your initial test between the RME and the MGB, when running a native setup, the MGB does give better results, but you do not speak of buffer sizes involved with the two soundcards ? I think i got a glimpse of the MGB running at 40 odd samples ? But how stable at what load ? Pandoras...
also, it would a very curious test to compare all of this against the Avid's TDM architecture with the older consoles, and the AAX architecture with the newer ones, alas waves does not do AAX DSP...
AVId did bring this evil upon us, but I still do believe they have the best plugin/Virtual sc solution.
Cheers!
Sidhu
« Last Edit: January 05, 2015, 12:45:29 pm by Nitin Sidhu »
Page created in 0.041 seconds with 22 queries.
