Pages: 1 2 [3]  All   Go Down
Author Topic: Using a router as a switch  (Read 4873 times)
Tim Padrick
  • Indianapolis
    • T.P. Audio
Re: Using a router as a switch
« Reply #20 on: November 09, 2014, 05:50:47 pm »
This setup works.  See if this is of any help: http://padrick.net/LiveSound/IPaddys2.jpg
« Reply #21 on: November 10, 2014, 12:06:09 am »
Tim, that won't work for him.  He wants discrete DHCP when the racks roll out individually and the ability to connect them all together for larger events without reconfiguration.
To me, the only way to accomplish this is to have a subnet in each cabinet with DHCP and a central router to route between the subnets.
Sent from my To Be Filled By O.E.M. using Tapatalk
Tom Bourke
    • http://www.cwalv.com
« Reply #22 on: November 10, 2014, 04:26:44 am »
No, that's not accurate.
From what I have seen in documentation on DHCP it is a first server to answer wins sort of protocol.  So you can have 2 DHCP servers on the same subnet if they hand out IP addresses from different ranges.
For the OP's configuration I would do similar to the following:
Rack 1:
Router IP 192.168.1.1
WLS units get static IP 192.168.1.11 to 19
Hand out DHCP 192.168.1.110 to 119
Rack 2:
Router IP 192.168.1.2
WLS units get static IP 192.168.1.21 to 29
Hand out DHCP 192.168.1.120 to 129
Rack 3:
Router IP 192.168.1.3
WLS units get static IP 192.168.1.31 to 39
Hand out DHCP 192.168.1.130 to 139
Also have a label listing addresses 192.168.1.200 to 250 as safe static IP addresses.
The router listed has auto uplink ports so just one cat5 rack to rack and plug the laptop into the most convenient rack.  Do not use the WAN port on any of the routers.
Having said all that, I think that having a "no network config necessary" is nice but not totally needed.  If a tech can't set an IP address on his or her laptop do you really want them to have access to your wls system?
Pages: 1 2 [3]  All   Go Up
Page created in 0.065 seconds with 23 queries.
