Author Topic: Portable Generator 4 − 20amp 120v  (Read 2142 times)
Rick Alan
« on: September 23, 2014, 07:18:01 pm »
Looking for portable generator for events where I do not need to rent trailer style generator. Needs 4 − 20amp 120v.
I have searched the forum for specific info with no luck so any insight would help.
Thanks
Robert Piascik
  • Hilliard, OH (near Columbus)
Re: Portable Generator 4 − 20amp 120v
« Reply #1 on: September 23, 2014, 08:54:27 pm »
How about a Honda EU7000iS? I think that would fit the bill
Pi Entertainment Services
Midas M32R / MR18
Behringer X32R / XR12
Danley SH50 / SM80 / TH118 / TH115
Fulcrum Acoustic fa22ac
RCF NX 12SMA
Yamaha DSR112
Powersoft X4 / M50Q
Crown iT8k / Xti6k
Rick Alan
« Reply #2 on: September 23, 2014, 08:58:26 pm »
Thats what I was thinking with some Furman power conditions too but did not know if there was anything else on the market that I was missing.  Also just learned you can run 2 honda eu generators of the same model in parallel.
g'bye, Dick Rees
  • Duluth
« Reply #3 on: September 23, 2014, 09:31:15 pm »
What in the world do "power conditioners" have to do with anything?
You need to figure your power draw first.  What EXACTLY are you using for sound?  Any lights?
Cailen Waddell
« Reply #4 on: September 23, 2014, 11:23:30 pm »
Rick you might do well to look through some other threads here on honda generators.  Lots of really excellent information that should get you the information you need.  I agree a 7000 will probably fit the bill, but knowing what equipment you have is helpful.  Additionally, the honda probably has the capacity but doesn't have 4 nema 5-20r receptacles so some other power distribution gear will be needed.
Mark Cadwallader
  • Helena, Montana USA
« Reply #5 on: September 24, 2014, 10:32:38 am »
If you really need four 20 amp 120v circuits (80 amp capacity), I don't think the EU7000is will do the job for you. Its rated output is only about 45 amps at 120 volts. Hence the questions from the others about the specific equipment to be used. Mark C.
Guy Holt
« Reply #6 on: September 24, 2014, 06:20:45 pm »
There are two options that will give you 80 Amps at 120V  from portable generators.  One is to use the Honda EB10000 and use a 10kVA 240-to-120V step-down transformer to convert the 240V output to 120V.  The EB10000 is an open frame industrial machine and is quite load. If you use a transformer with taps, you will be able to run the generator at a further distance, or from around the corner of a building, and boost the voltage on the transformer to compensate for the subsequent line loss.
The second option is to parallel two Honda EU7000s. With a paralleling box will get 50 Amps on two legs that are 180 degrees out of phase. But, again you will need to use a 10kVA 240-to-120V step-down transformer to convert the 240V output of the paralleling box to 120V.  It will help to reduce the cross current circulating between the two generators if the paralleling box offers a means of adjusting the load sharing between the two generators.  Use this link for more details on how to parallel Honda EU7000s  and even the older EU6500:http://www.screenlightandgrip.com/html/emailnewsletter_generators.html#anchorParallelingEU6500s.
Guy Holt, Gafer
Screenlight & Grip
Page created in 0.1 seconds with 23 queries.
