Pages: 1 [2] 3 4   Go Down
Author Topic: Steve M Smith approching 1000 posts  (Read 6069 times)
Mike Sokol
Re: Steve M Smith approching 1000 posts
« Reply #10 on: September 14, 2014, 08:04:49 am »
If you put two in series and double the voltage the current draw still doubles.
Not true. Voltage divided by Resistance equals Current and Voltage times Current equals Wattage, so if you double the voltage and double the resistance, the current stays the same but the wattage doubles. This doubled wattage is distributed across two dogs, with each one dissipating half the total wattage. So two hot dogs in series on 240 volts will cook at the same rate as a single dog on 120 volts. Just like two 120-volt light bulbs in series will work properly on 240 volts.
Quote
Has anyone done a monte carlo analysis on hotdog resistance?  If the resistance changes once the cooking process is complete you could have an auto turnoff circuit.
Found this on http://www.evilmadscientist.com/2007/cooking-hot-dogs-via-electrocution/
They confirm that the hot dog resistance goes up as it cooks. Plus you can stick LEDs in the electrified dog and they will light up from the gradient voltage. Cool.  8)
Mike Sokol
mike@noshockzone.org
www.NoShockZone.org
Steve M Smith
  • Isle of Wight - England
« Reply #11 on: September 14, 2014, 08:07:46 am »
So you can insert an LED as a 'hotdog cooked' indicator.  Just wait until it goes out.
Do you give everyone this sort of service as they approach 1,000 posts?
Steve.
Mike Sokol
« Reply #12 on: September 14, 2014, 08:34:28 am »
Only for contributors on this forum. You guys are the BEST.  ;D
Mike Sokol
www.NoShockZone.org
Jay Barracato
  • Solomons, MD
« Reply #13 on: September 14, 2014, 09:01:53 am »
Do it with a whole dill pickle. The brine adds a surprise.
Sent from my DROID RAZR HD using Tapatalk
https://www.youtube.com/watch?v=5FO0IKUTkJ0
Jay Barracato
Robert Piascik
« Reply #14 on: September 14, 2014, 09:02:34 am »
Sometimes I'm astounded by what I learn on this forum. Thanks everybody!
Bob "posting-cheap-replies-to-try-to-get-to-1,000-faster" Piascik
Pi Entertainment Services
Midas M32R / MR18
Behringer X32R / XR12
Fulcrum Acoustic fa22ac
RCF NX 12SMA
Yamaha DSR112
Powersoft X4 / M50Q
Crown iT8k / Xti6k
Frank Koenig
« Reply #15 on: September 14, 2014, 12:04:06 pm »
I first saw this hotdog cooker design in some "Fun for Boys" sort of book in elementary school. What bothered me then, and still bothers me now, aside from the obvious electrical safety issues, is the unknown electrochemical nonsense going on at the interface between the dog and the electrodes. I know it's AC, but still. I'm not going to eat the ends of the dog unless you use, say, Pt forks.
And now I'm one (useless) post closer to winning my own hotdog cooker. -F
Steve M Smith
« Reply #16 on: September 14, 2014, 12:15:50 pm »
Even then, the ends won't be cooked as there is no voltage drop (practically) and therefore, no current through the length of hotdog which has fork in it.
Steve.
Frank Koenig
« Reply #17 on: September 14, 2014, 12:36:12 pm »
Yep, you're prob right. The current density will assume a "field line" pattern that's highly dependent on the shape of the electrodes. It seems you'd want a small cup, or even a ring, that tightly fits each end of the hotdog to get the most uniform current density. Oh crap! I'm designing one now. Stop me.
Actually, has anyone here any direct experience with one of these? That is the criterion, after all, when we're talking about speakers, etc. on this forum. -F
Steve M Smith
« Reply #18 on: September 14, 2014, 12:40:20 pm »
Already designed.  Just solder wires onto a couple of metal thimbles.
Steve.
Frank Koenig
« Reply #19 on: September 14, 2014, 12:45:39 pm »
[/quote]
Or how about the "transverse mode" cooker? Press the hotdog between two energized plates. That might get good uniformity (and higher current for a given voltage). Thermal conductivity works in our favor, evening out the current problems. I'll be quiet now. -F
Pages: 1 [2] 3 4   Go Up
Page created in 0.061 seconds with 25 queries.
