Author Topic: DOD RTA advice needed  (Read 9571 times)
James Deni
« on: September 01, 2014, 07:52:03 pm »
I have been looking for a way to effectively set up an equalizer I'm installing in my home system. Today I impulsively purchased a DOD RTA on ebay - then realized it does not come with a microphone. The owner's manual states the calibrated microphone that comes with the unit (again - none with this used unit) must be used and plugged into the front panel - it says that other microphones may sustain damage if plugged into the unit. Is this because of a special configuration they are using, or can I actually use another RTA mic on the unit?
Jim Deni
Craig Leerman
  • Global Moderator
  • Do Not Read This!
Re: DOD RTA advice needed
« Reply #1 on: September 01, 2014, 10:23:13 pm »
Jim Deni
Please go to your profile and change the "Name" field to your real full name as required by the posting rules clearly displayed in the header at the top of the section, and in the Site Rules and Suggestions in the Forum Announcements section.
Craig
TechWorksReno.com
Facebook.com/TechWorksReno
Pinterest.com/TechWorks0492
Alfredo Prada
« Reply #2 on: September 02, 2014, 11:47:30 pm »
This unit is similar to Rane's RA 30, it has a brand specific powered mic (Rane takes 1 or 2 volts?), of course you can use the aux mic input in the back, but it look like you will need a phantom power source in between the mic and RTA, as measurement mics are condensers (with the exception of battery powered mics). The RA 30 does not provide power and the DOD RTA's manual does not specify, so it is likely it does not.
« Reply #3 on: September 03, 2014, 03:12:31 am »
With the 4 or 5 LED display the resolution is quite poor on these units.  They are fun eye candy, useful (sorta) for finding feedback quickly.  They make great rack fillers.
Wish you had asked us first.
I can't say enough for TrueRTA, get at least the level 2 license.  You can calibrate your MIC and with an inexpensive sound level meter, calibrate the generator.  It's a serious tool and will lead you down the path of testing systems and loudspeakers.
You can pick up decent measurement microphones for $40 on eBay.
Also you will need a USB interface with phantom power for the measurement MIC.  I recommend the Tascam's.  Again, under $60 on Flea Bay
Good luck!
Sent from my To Be Filled By O.E.M. using Tapatalk
Merlijn van Veen
    • www.merlijnvanveen.nl
« Reply #4 on: September 03, 2014, 10:31:11 am »
I'd like to point out that a Real Time Analyzer can't tell time and polarity, doesn't have the required resolution to discern tonal phenomena from spatial and potentially echo phenomena, doesn't exclude reverberant energy and can't discern noise from signal.
But maybe that suffices for a home system.
RTA's are easy to operate and don't require education. Unfortunately they also provide low quality data.
If you're thinking of spending money, consider a dual-channel FFT analyzer like Smaart, do a seminar and develop a skill set while simultaneously optimizing your home system.
My 2p
« Last Edit: September 03, 2014, 04:45:14 pm by Merlijn van Veen »
g'bye, Dick Rees
  • Duluth
« Reply #5 on: September 03, 2014, 10:42:29 am »
RTA's are easy to operate and don't require education. Unfortunate they also provide low quality data.
If you're thinking of spending money, consider in a dual-channel FFT analyzer like Smaart, do a seminar and develop a skill set while simultaneously optimizing your home system.
My 2p
RTA doesn't, SMAART does but costs a bit and requires a good bit of study.
I still use EARS.
Cailen Waddell
« Reply #6 on: September 03, 2014, 10:59:15 am »
Room EQ wizard is a good entry level free tool to home theater enthusiasts.   Look on the home theater shack forums.  Buy a calibrated mic from parts express, and you will be set to start to learn.
g'bye, Dick Rees
  • Duluth
« Reply #7 on: September 03, 2014, 11:01:21 am »
What does that tell you that your ears can't?
Cailen Waddell
« Reply #8 on: September 03, 2014, 11:08:59 am »
My perspective is this: most people, maybe even the OP, who buy an eq for their home are trying to fix something their ears perceive to be wrong.  If they fiddle with it and it sounds good to them, great.  The OP had bought an RtA, so perhaps he is trying to get a greater understanding of what is going on. A free tool that shows impulse response and phase, let's him make multiple measurements and plot them, etc, is going to help him 'see' what he is hearing much more than a 5 segment led RTA.  Everyone learns differently, and visuals help some people.
For example, If you can hear phase/alignment issues and correct them without any tools but your ears, good for you, not everyone can.
g'bye, Dick Rees
  • Duluth
« Reply #9 on: September 03, 2014, 11:12:53 am »
And just how does an RTA show phase and alignment?
It doesn't...
Page created in 0.058 seconds with 22 queries.
