Pages: [1] 2 3  All   Go Down
Author Topic: AC connectors  (Read 5942 times)
Nate Armstrong
AC connectors
« on: August 04, 2014, 03:06:52 pm »
I was just curious which single phase  connectors people normally carry with them, for gen sets and what do you come across the most at venues with out cam-locks
Re: AC connectors
« Reply #1 on: August 04, 2014, 04:37:29 pm »
We carry either 4/0, 2/0 or #2 tails to Cams.
Cailen Waddell
Re: AC connectors
« Reply #2 on: August 04, 2014, 06:00:18 pm »
If you are NOT considering cam locks or tails for can locks, then a California connector, 50a/240v 4 wire is pretty standard.  Most gensets have several already on the generator.
TJ (Tom) Cornish
  • St. Paul, MN
Re: AC connectors
« Reply #3 on: August 04, 2014, 06:03:53 pm »
The other missing plug from the list is the NEMA 14-50P.
Nate Armstrong
Re: AC connectors
« Reply #4 on: August 05, 2014, 11:09:00 am »
tails to cam-locks
50Amp Hubbell CS6365c Locking 125/250  250v 2pole 4wire (California connector)
50Amp Hubbell HBL9451c  L14-50   250v 2pole 4wire ( Rv style )
30Amp Hubbell HBL2711 L14-30P Twist lock 250v 2pole 4wire
30Amp L10 -30 ( Pre 1956 dryer Will not use )
____________________________________________________
Single Pole
30Amp Leviton 830-t  TT-30R  125v 1pole (RV Style)
30Amp Hubbell HBL2611 L5-30p 125v 30 amp 1pole ( Honda EUi generator )
30Amp Hubbell HBL9432c L14-30  ( Dryer Post 1956)
This is what I planned on having in my AC power  case.
Re: AC connectors
« Reply #5 on: August 05, 2014, 11:48:59 am »
tails to cam-locks
Single Pole
For a common household clothes dryer, you don't need the "L".  That's for "locking" as in Twist-Lock.
TJ (Tom) Cornish
  • St. Paul, MN
Re: AC connectors
« Reply #6 on: August 05, 2014, 11:57:56 am »
tails to cam-locks
Single Pole
I've never seen an L14-50.  I have seen many 14-50.
The next question is what do you put after the plug?  Your list has a lot of items in it; not all of them can be handled the same way - i.e. what do you plan to do with an L5-30?
Re: AC connectors
« Reply #7 on: August 05, 2014, 12:01:34 pm »
You went where I was headed next...
{gets popcorn}
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
Re: AC connectors
« Reply #8 on: August 05, 2014, 12:06:14 pm »
tails to cam-locks
Single Pole
NEMA designators
Leading L is locking
Trailing P is plug
Trailing R is receptical
Digits to left of hyphen is connector series
Digits to right is capacity
Ray Aberle
    • Kelcema Audio
Re: AC connectors
« Reply #9 on: August 05, 2014, 12:52:28 pm »
So, Nate, it might be time to take a step back and identify your actual needs for power connections; i.e. having the ability to adapt from a TT-30R into your distro might be nice, but if your power needs are such that the TT-30R won't supply your needs, then there's no use having that adapter.
So, in no particular order, you should be considering...:
- do you have a mains distro, and what connection does it need?
- do you have amp rack packs that need power, and what connections do they require?
- do you have (or need) the ability to break higher amperage/voltage services into the levels that you need?
- how often will all of these capabilities be required?
If you're just used to using a pile of 20A edisons, if you want to have 220V capabilities, well, as listed, there's several to choose from. Do you really want/need to be able to adapt anything and everything?
The most common things you will see:
- cams (on generator or at venue)
- 14-50 (at venues, maybe on a large AC distro coming from cams; this is getting more common at electrical houses who do, say, RV drive ins and need to provide multiple RV power points)
- CS6364/5 ("California Connector") on generators, at some venues
Here's what I did: I have a set of cam tails to 5 wire, with distro, that powers my amp racks, when I have 3 power available and using the L21-30 rack packs in my amp racks.
For smaller events, that just need a spider box or two, I have a pile of 50A twist feeder, and a pair of spider boxes. I built a distro that takes the CS6365 and goes into a small panel with 2- L14-30 and 2-20A courtesy plugs. (I have L14-30 input rack packs as well, and swap those out in my racks if required.) I made two adapters: 1 14-50P to CS6364, and one bare wire to CS6364. I have a selection of 50A breakers. So, I can tie into a panel if needed, or I can adapt a venue range plug into the generator twist. Or I can run off the generator with the twist lock connections. I feel better about giving a a spider box to someone at an event, as opposed to the distro.
The key is to have the minimum amount of connectors/adapters. This saves you money, as well as makes setup easier when it is less confusing. Easier to have someone else help and harder for them to screw it up. Saves weight in the AC cable trunk as well. I don't even bring all of these aforementioned adapters with me, on every event-- I pack AC as needed. "A bit extra" in case there's an unknown, but with a good advance, there should be little in the unknown category.
Thoughts?
-Ray
Kelcema Audio
Re: AC connectors
Pages: [1] 2 3  All   Go Up
Page created in 0.054 seconds with 22 queries.
