Author Topic: Earthing Pit  (Read 10870 times)
Frank DeWitt
    • LBP DI Box
Earthing Pit
« on: August 04, 2014, 10:12:11 am »
I ran across this web site talking about Earthing Pits as opposed to ground rods.  It is interesting.  It reminds me of Mikes inverted bed of nails.
http://www.nairaland.com/1233943/contact-us-electrical-mechanical-plumbing/4
and pictures
Not to Code
Mike Sokol
Re: Earthing Pit
« Reply #1 on: August 04, 2014, 10:18:29 am »
Very cool. My carpenter buddy is coming by this week for the bed-o-nails experiment. I have a 2 ft by 2 ft piece of plywood made up with sheet metal on the surface. He's going to use his big framing nail gun to drive in a hundred or so nails while it's on the ground. Then I'll do a fall of potential test during wet and dry weather to see if it's an idea worth pursuing. Yes, I'll take pictures.
Mike Sokol
mike@noshockzone.org
www.NoShockZone.org
frank kayser
Re: Earthing Pit
« Reply #2 on: August 04, 2014, 11:24:12 am »
It would be interesting to know more about the pit - how deep, how long the ground rod(s) are.  What would it be about the soil conditions there that requires that level of detail.  The post says the pit contains "Digging earth pit for earthing of the building using industrial salt, charcoal, copper earth rod,"  What would be the need for charcoal?
frank
Frank DeWitt
    • LBP DI Box
Re: Earthing Pit
« Reply #3 on: August 04, 2014, 11:59:20 am »
frank
I meant to give a different link with more info.  Here it is.
http://electrical-engineering-portal.com/earthing-in-electrical-network-purpose-methods-and-measurement
Not to Code
Jay Barracato
  • Solomons, MD
Re: Earthing Pit
« Reply #4 on: August 04, 2014, 02:27:27 pm »
Probably a sacrificial anode. The carbon would be oxidized to carbon dioxide before the copper would be oxidized.
Sent from my DROID RAZR HD using Tapatalk
« Last Edit: August 04, 2014, 02:29:37 pm by Jay Barracato »
Jay Barracato
Frank DeWitt
    • LBP DI Box
Re: Earthing Pit
« Reply #5 on: August 04, 2014, 03:20:25 pm »
From the document
Make a mixture of Wood Coal Powder Salt & Sand all in equal part
Wood Coal Powder use as good conductor of electricity, anti corrosive, rust proves for GI Plate for long life.
The purpose of coal and salt is to keep wet the soil permanently.
The salt percolates and coal absorbs water keeping the soil wet.
Care should always be taken by watering the earth pits in summer so that the pit soil will be wet.
Coal is made of carbon which is good conductor minimizing the earth resistant.
Salt use as electrolyte to form conductivity between GI Plate Coal and Earth with humidity.
Sand has used to form porosity to cycle water & humidity around the mixture.
Well, It's August.  I must go water my ground pit.  I don't think that will happen in most cases.
Not to Code
Mike Sokol
Re: Earthing Pit
« Reply #6 on: August 04, 2014, 03:29:53 pm »
Make a mixture of Wood Coal Powder Salt & Sand all in equal parts. Wood Coal Powder use as good conductor of electricity, anti corrosive, rust proves for GI Plate for long life.
Sounds like a spell from Harry Potter movie.  8)
Mike Sokol
www.NoShockZone.org
Kevin Graf
Re: Earthing Pit
« Reply #7 on: August 04, 2014, 04:36:33 pm »
From a link in another forum. A section on building Earthing Pits.
"Earthing in electrical network purpose, methods and measurement"
All this interest in getting connected with Mother Earth.  Is someone expecting another thunderstorm?
Speedskater
Re: Earthing Pit
« Reply #8 on: August 05, 2014, 01:16:56 am »
Back in "the day" Erico made a smaller version of this chemical ground system http://www.erico.com/products/ChemRod.asp
It was a hollow rod that leached a saline solution to reduce the resistance of the surrounding soil.  AM Radio stations depending on earth as a ground wave radiator.  Having a good earth made a huge difference in your signal.  Going out a full wave length every 30 degrees from the tower with a trench and cadwelded sectional ground rod produced a significant increase in radiation.  I don't remember the megger values we could achieve it was too long ago.
I am sure that a smaller version would be very useful for any facility trying to decrease the noise floor or utilizing an RF cage.
Jerome Malsack
Re: Earthing Pit
« Reply #9 on: August 05, 2014, 12:17:50 pm »
Another article on Grounding by a radio station and tower.
http://www.copper.org/applications/electrical/pq/casestudy/nebraska.html
http://ewh.ieee.org/r3/nashville/events/2011/Grounding-2011%20color.pdf
This second one has different soil types.
Re: Earthing Pit
Page created in 0.078 seconds with 20 queries.
