Merlijn,
I recently picked up the bullet M5 and haven't had much luck getting it programmed for use. Is there anything you could point me towards that you may have run into
It's been a while, it's pretty much set and forget, so forgive me if the details aren't completely accurate.
First you have to decide if you want to use the bullet as router or access point (or any of the other modes).
I use it as AP connected to an existing router.
I followed the manual which is pretty straight forward IMO as are the wizards in the software.
Make sure that you turn off AIRmax. This is proprietary technology that doesn't work with other brands.
If you use 5 GHz, depending on you locale and regulations, the bullet has to scan for free channels. This can take up to 10 minutes and caught me of guard in the beginning.
Regards,
Merlijn
