Author Topic: Processing  (Read 2573 times)
Steven Anthony Mercier
Processing
« on: May 24, 2014, 10:44:20 pm »
Do i need to use a processer with my subs...got 2 Yorkville tx9s ?
  • Old enough to know better
  • Audio Plumber
Posting Rules
« Reply #1 on: May 24, 2014, 11:03:38 pm »
Processing
« Reply #2 on: May 25, 2014, 02:47:11 pm »
How important is adding a processer for your subs...is it nessesary ? Once i power my 2 Yorkvilles tx9s properly...ap6040 yorkville amp, instead of the crown xti 4002 which is all i have for them now..i'll probably hear a big difference. Can anyone comment on this ?     Thanks in advance!
« Last Edit: May 25, 2014, 10:55:48 pm by Steven Anthony Mercier »
Tim Padrick
  • Indianapolis
    • T.P. Audio
Re: Processing
« Reply #3 on: May 26, 2014, 08:10:38 am »
You certainly need at least a high-pass filter (set per manufacturer's recommendation) and a low-pass filter (set appropriately for the sub, the tops, and the high-pass that's on the tops).  A used DR260 would be a good choice I think.
Mike Maly
Re: Processing
« Reply #4 on: May 26, 2014, 10:45:40 am »
The Crown XTi has the needed processing when used with a laptop.
-Maly Sound:
Hear the difference
Cailen Waddell
Re: Processing
« Reply #5 on: May 26, 2014, 11:16:33 am »
In addition to having the right processing, the crown has close to the right amount of power for these subs.  They spec a 1700w program power.  The crown can do 1200w.  You may be a couple, maybe 5 dB shy of their maximum performance but if you are running them that hard you probably don't have enough rig for the gig.
I think of you process them correctly on the crown you will hear a difference, especially over unprocessed.  Changing amps (in general given a reasonable quality amp) won't make a difference in how the sound, just how loud they will go.
Samuel Rees
  • Washington, D.C.
Re: Processing
« Reply #6 on: May 26, 2014, 12:00:24 pm »
How did you get 5db from 1200-1700 watts?
Re: Processing
« Reply #7 on: May 27, 2014, 02:23:37 pm »
Thanks for the advice!
Re: Processing
Page created in 0.038 seconds with 25 queries.
