Author Topic: Speaker with Omnimount 60.0 Mounting Pattern on the Bottom?  (Read 5365 times)
Sean Chen
    • Pristine Audio
« on: March 20, 2014, 12:38:33 am »
Hello, I am doing an install job for a revamping venue that had the sound equipments all stripped when it went out of business years ago, leaving only the speaker wires and wall-mount bracket that proved too difficult to remove.  The wall bracket looks to be Omnimount 60.0 WB wall bracket with the speaker interface plate facing up, hole pattern 70 mm wide x 127 mm long. Is there any speaker out there that has this mounting pattern on the bottom of the speaker?
If not, drill new holes?
Thanks.
« Last Edit: March 24, 2014, 12:45:49 pm by Sean Chen »
Pristine Audio
Authorized dealer for Allen & Heath, Countryman, Danley Sound Labs, Dynaudio, Electro-Voice, Gator Cases, HK Audio, K&M, Mackie, MiPro, RCF,  Yorkville
www.pristine-audio.com
Scott Carneval
    • Cenero Audio Visual
Re: Speaker with Omnimount 60.0 Mounting Patter on the Bottom?
« Reply #1 on: March 20, 2014, 08:04:40 am »
Hello, I am doing an install job for an revamping venue that had the sound equipments all stripped when it went out of business years ago, leaving only the speaker wires and wall-mount bracket that proved too difficult to remove.  The wall bracket looks to be Omnimount 60.0 WB wall bracket with the speaker interface plate facing up, hole pattern 70 mm wide x 127 mm long. Is there any speaker out there that has this mounting pattern on the bottom of the speaker?
Thanks.
Not sure about a new speaker with that pattern.  But I would be very cautious about using an existing mount, especially when you're unsure of the history behind it.  If it fails, you're responsible.  Is there another way to mount the speaker(s)?  What would you have done if this mount wasn't already there?  Do that.
Sean Chen
    • Pristine Audio
« Reply #2 on: March 20, 2014, 08:29:06 am »
The existing mount appears very secure, with three 3/8" bolts from inside the brickwall. If they don't pass the structural check, I'll do something else.
Thanks for the advise.
Pristine Audio
Jason Lavoie
« Reply #3 on: March 20, 2014, 04:47:18 pm »
Thanks.
Fulcrum CX series? http://www.fulcrum-acoustic.com/assets/pdf/Spec%20Sheets/Prod%20Spec,%20CX1295%20v11.pdf
Not sure what your budget is, as these aren't cheap and they must be run with a DSP but they sound great.
Jason
Sean Chen
    • Pristine Audio
« Reply #4 on: March 24, 2014, 12:48:58 pm »
Jason
Yes, that is out of client's budget. I got a pair of different style arm Omnimount 60.0 WA that will work with Yorkville C12 with same mounting pattern on the back.
Pristine Audio
Joseph D. Macry
  • Austin TX
Re: Speaker with Omnimount 60.0 Mounting Pattern on the Bottom?
« Reply #5 on: March 26, 2014, 12:54:13 pm »
Thanks.
The only time I have used those WB bottom-attached mounts were for Community CPL-47s, which are now a discontinued line. Current Communities would use the WA back-mounted series.
Note that Omnimount has discontinued the larger speaker mounts (anything over 25 lbs). There are other brands that use similar hole patterns. But you can't get those Omnimounts new anymore.
Joseph Macry,
Austin, TX
Jonathan Kok
  • Toronto
« Reply #6 on: March 26, 2014, 05:50:55 pm »
Any names on other brands? The only one I've found was Adaptech (FA pointed them out). But these are ceiling only; I need wall-mount. I could build my own modification for a ceiling mount version, but would prefer a one-piece solution like Ominimounts.
http://www.adapttechgroup.com/multimount_c.html
Joseph D. Macry
  • Austin TX
« Reply #7 on: March 27, 2014, 01:32:10 pm »
I have not researched this much. I did get pointed to a UK company called Power Drive Mounts. http://mypowerdrive.com/
Joseph Macry,
Austin, TX
Page created in 0.06 seconds with 23 queries.
