Author Topic: Wide Shallow Room for Rock Shows... PA Install?  (Read 5446 times)
Ryan O John
    • ryanojohn.com
« on: February 18, 2014, 06:15:07 pm »
At most 40ft of coverage depth required...about 30ft coverage required horizontally out from the downstage edge of the stage.  Not enough vertical space for a legit array, nor do I really think it makes sense, unless someone can explain to me otherwise...
Looking at D&B Q10 pair per side, or L Arc II 3 per side...
SB28s, or similar...
Looking for something that can put on a 'full on rock show.'
Suggestions?
« Last Edit: February 18, 2014, 06:19:45 pm by Ryan O John »
Ryan John
Product Manager | Avid Live Sound
Brad Weber
  • Marietta, GA
Re: Wide Shallow Room for Rock Shows... PA Install?
« Reply #1 on: February 19, 2014, 09:22:56 am »
How wide is the room?  Where and how high can you fly the speakers?  Do you need coverage to the sides of the stage?  It would really help to have pictures or a floor plan showing the stage and audience area.  It's a bit hard to address specific products without knowing the dimensions involved.
What do you mean by a "legit array"?  Do you have to meet riders and if so, are there particular brands or products that are typically acceptable or not?  Do you have a budget?
Will you have amplifier channels and processing so that each box in an array can be processed and amplified independently or were you thinking all the speakers in an array on one channel?  A simple left and right array configuration in a wide, shallow room may result one box in an array having to 'throw' much further than others and thus their ideally being independently processed and amplified.
In very wide, shallow rooms it is often difficult to get proper stereo coverage where each speaker or array actually provides good coverage of the entire listener area by itself from just a single left and right speaker or array.  Would a mono speaker system be a viable option?
Ryan O John
    • ryanojohn.com
« Reply #2 on: February 19, 2014, 09:39:12 am »
lets say the stage is 24ft wide, the room is 75ft wide, 35ft deep.
there is only about 13ft of vertical space, and really only 3ft before you're in sight lines.
Quote
When I say legit array, I mean any hang of substantial length, since there's only about 3ft of vertical space that can be realistically used.
Quote
Amps will be purchased with the speaker system, so that's entirely variable (the stuff I've suggested already has to run with D12s or LA8 amps, so those are part of the buy).  There is a budget, but it's not really relevant, as I'd just like some ideas for systems that you guys may suggest for a wide shallow space, WITHOUT budget in mind.
Thanks so much!
Ryan John
« Reply #3 on: February 19, 2014, 08:19:34 pm »
So why do you think you need a "hang of substantial length" for a room that is 35' deep and 75' wide??????
g'bye, Dick Rees
  • Duluth
« Reply #4 on: February 19, 2014, 09:02:53 pm »
Hey, Ivan!!!!
How's it hangin'???
« Reply #5 on: February 20, 2014, 07:46:31 am »
Hey, Ivan!!!!
How's it hangin'???
Hopefully by aircraft cable attached to solid structure above.  wink wink nod nod--------
Ryan O John
    • ryanojohn.com
« Reply #6 on: February 20, 2014, 10:32:14 am »
Because I've never heard any "line array" under 3 boxes that sounded remotely good?
Ryan John
g'bye, Dick Rees
  • Duluth
« Reply #7 on: February 20, 2014, 01:21:17 pm »
Sure.  But there are good sounding smaller rigs out there.  I hear a LOT of line arrays that sound like s*** even though there are enough boxes.  It's as easy or easier to set up a LA rig wrong as it is to set up a trap-box rig wrong.  So I'd not discount OE when evaluation rig performance.  In music styles, the top 5% of each genre "sounds good".  I suspect that the cream rises to the top regardless of subject.
LABster TJ Cornish has gone through the smaller, true line array stuff very carefully and is now using a JBL rig which sounds very, very good and would likely be a viable option for your application.
Perhaps he'll chime in.  I'm sorry I don't remember the model #'s off the top of my head.
Samuel Rees
  • Washington, D.C.
« Reply #8 on: February 20, 2014, 02:31:58 pm »
Responses to this so far seem sort of confusing. The forum spends a lot confronting people who assume they need a line array when it may be inappropriate because they would really have merely a dash... And this poor fella walks in saying what is essentially Danley's greatest dream, "I don't want a dash array - a strong point source makes more sense in this room", and the topic turns back to line arrays. How did the forum not pounce on the occasion to talk about ARC, Danley and D&B C instead?
EDIT: Not trying to start an argument. I mean this in this best spirit of constructive conversation and steering the thread in a useful way to the OP.
« Last Edit: February 20, 2014, 02:36:00 pm by Samuel Rees »
Re: Wide Shallow Room for Rock Shows... PA Install? Put another way
« Reply #9 on: February 20, 2014, 05:07:03 pm »
Let's put it another way.
Why do you think a line array is the proper choice for a room that is 35' deep and wide?
Page created in 0.064 seconds with 22 queries.
