Author Topic: Q-SYS  (Read 2123 times)
Q-SYS
« on: January 24, 2014, 11:24:54 PM »
Greetings all.
I have been asked by a client to review the processing for a system installed over a year ago by a regarded local firm.  They used QSC power and processing.  QSC amps I'm familiar with, but Q-Sys, not so much.
I'm in the process of downloading the software now.
Anyone have advice, observations or other info regarding the use of Q-Sys?
Thanks for your insights.
Mike Maly
Re: Q-SYS
« Reply #1 on: January 25, 2014, 03:31:07 AM »
Check QSC's website. They have thorough training modules available.
-Maly Sound:
Hear the difference
Jeff Baumgartner
Re: Q-SYS
« Reply #2 on: January 25, 2014, 12:45:31 PM »
It's a extremely easy system once you spend a bit of time on it learning how it works.
I absolutely love mine.
If you have any specific questions, feel free to ask.
The tutorials on the QSC website were a tremendous help getting me started.
Jeff Baumgartner
Show Technologies Audio Visual
Re: Q-SYS
« Reply #3 on: January 26, 2014, 07:36:40 AM »
Thanks, guys.  Not sure what we'll be doing but the client isn't happy with a design over which they had no input (facility was under construction when they came to manage it).  The installers claim system limiting is speaker protection only (which I believe).  I need to show the client what's going on and come up with some options for them.  They'd like to re-use existing infrastructure if upgrades are adopted.
We shall see...
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
Re: Q-SYS
« Reply #4 on: January 26, 2014, 09:03:56 AM »
Tim, the speaker limiting inside of Qsys is not at all typical. You are required to put in RMS wattage, voice coil diameter, and if it's a cone or compression driver, maybe other perimeters too, it's been a little while.  Additionally, it appeared to me the peak limiting was done on a driver basis while RMS limiting is done on a speaker basis. I won't says that is the exact case, but sending one diver into hard limit will cause gain reduction for the others drivers in "the speaker."  I would recommend you verify RMS limiting voltage with a multimeter at the output of the amp.
Audio Systems Design Engineer
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
Re: Q-SYS
Page created in 0.055 seconds with 24 queries.
