That would be
Bill Whitlock, now AES committee chair on EMI/RFI.
From his recent PowerPoint:An Overview of Audio System Grounding & Interfacing
9/4/2012 page 201
Bill Whitlock
So-Called “Balanced Power”
• Properly called SYMMETRICAL power
• Has very seductive intuitive appeal
• NOT similar to balanced audio lines in any way!
• Uses transformer having 120 V center-tapped secondary
• Both line and neutral output blades are energized at 60 V
• Although advertising often implies endorsement, NEC seriously restricts
its use – because it’s potentially dangerous!
• ONLY FOR PROFESSIONAL USE
• NOT to be used with lighting equipment, especially screw-base bulbs
• MUST have GFCI at outputs
• Only technical function is to reduce leakage currents
• Leakage currents are trivial system noise sources
• Reported noise reduction generally less than 10 dB
• Any real benefit likely due to its clustered outlets
This is an example of “marketing gone wild” if ever there was one!
http://centralindianaaes.files.wordpress.com/2012/09/indy-aes-2012-seminar-w-notes-v1-0.pdf
