Author Topic: Replacement Horn Lens to narrow throw on QSC K10  (Read 7202 times)
Scott Blackwell
  • "Trust me it's not too loud"
    • Rutherford Design- Audio / Video / Lighting
« on: October 18, 2013, 03:41:11 am »
I have a client with a small church, 150 seats, that has purchased 4 K10's and wants me to fly them for them. @ 90 x 90 it's gonna be a problem. I was looking at replacing the horn lenses to narrow the vertical and horizontal patterns to 60 x 50 so I could vertically stack the boxes.
The room is typical small Church. 45'' wide about 65'' deep in front of FOH speakers.
I was looking at this as a possible option.
http://www.usspeaker.com/Faital%20Pro%20LTH102-1.htm
Thoughts? Suggestions?
Thanks.
Scott Blackwell
Systems Specialist
Rutherford Design
  • Old enough to know better
  • Audio Plumber
Posting Rules
« Reply #1 on: October 18, 2013, 07:26:14 am »
Thanks.
Scott Blackwell
QSC K10 replacement horn lens to narrow vertical dispersion
« Reply #2 on: October 18, 2013, 11:53:10 pm »
I have a client who purchased 4 K10's and wants me to install them at his church. 45' wide 65' deep in front of pic points. I was looking at replacing the horn lens and vertically stacking the boxes with the top box upside down, however the 90 x 90 will be an issue. I am looking at these
Thoughts?
Scott Blackwell
Systems Specialist
Rutherford Design
Re: QSC K10 replacement horn lens to narrow vertical dispersion
« Reply #3 on: October 19, 2013, 01:22:35 am »
What does QSC say?
Tim Perry
  • Utica-Rome NY
« Reply #4 on: October 19, 2013, 02:57:00 am »
Thoughts?
Don't be silly.  Just put up one per side and use the other 2 for floor monitors
« Last Edit: October 19, 2013, 10:46:03 am by Tim Perry »
Tom Young
  • Global Moderator
Re: Replacement Horn Lens to narrow throw on QSC K10
« Reply #5 on: October 19, 2013, 08:04:02 am »
If you change the horn you also change the cubic volume that the woofer sees, the frequency response of the HF driver, the acoustic output of the HF driver and the alignment between woofer and HF driver.
What do you end up with ? Who knows.
Not a good idea.
Tom Young
Oxford CT
203-888-6217
Tim Perry
  • Utica-Rome NY
« Reply #6 on: October 19, 2013, 10:48:30 am »
...or rig it as a dual PA... 2 for vocals 2 for instruments.
« Reply #7 on: October 19, 2013, 10:49:16 am »
Thanks.
You may not end up with what you think for the following reasons.
1: have you looked at the polar patterns of the horn you are suggesting?  It is only 50 vertical down to around 8Khz ish. So you only get the "control" in the top octave or so.  Is that really doing any good?
2: When you use a narrower pattern horn of the same size-the freq to which it has control goes UP-so there us usually LESS pattern control-especially where you need it.
3: Remember that when you get below the point to which the horn has control the pattern actually FLIPS-so it is opposite of what you "think" it is.
4: As Tom said-when you put a different horn on a driver all sorts of things are going to change.  The actual loading on the driver-which means the impedance is going to change-so the output and freq response is going to change.  Assuming there is delay to match up the woofer and HF driver-that is going to change due to the HF driver being in a different location.  This will cause a notch in the response you will not be able to fix.
I am not saying it won't work-but in reality it is most likely not going to do what you think it is-or want it to.
But as with so may things audio if you "think" it made a difference-then it probably did-at least in your mind.
But measurements would prove otherwise.
But the REAL question is WHY did the customer buy speakers that won't do the job and have to be modified.  Overall it would have been much better to get a PROPER loudspeaker for the job-not something that a salesman talked them into.
But it happens all the time.  No wonder our industry is in such a  mess with bad sound systems all over the place.
Mike Pyle
  • Santa Rosa, CA
« Reply #8 on: October 19, 2013, 12:50:40 pm »
The K10 horn is molded into the front half of the cabinet. For that reason and others mentioned it would be best to sell the K10s if they won't work and buy something that will.
Mike Sullivan
« Reply #9 on: October 19, 2013, 01:37:46 pm »
Thanks.
That is one tiny church! :P
I agree with above, either only use two (that would be all you need)
When you're reading a topic, and the word "Danley" comes up...RUN!!!
Page created in 0.145 seconds with 24 queries.
