Author Topic: smarrt7 and yamaha01v96i  (Read 5546 times)
ron lavenski
« on: October 17, 2013, 12:11:23 pm »
can I use smart7 with my 01v96i with out an external interface?
Arthur Skudra
Re: smarrt7 and yamaha01v96i
« Reply #1 on: October 17, 2013, 02:00:10 pm »
As long as Yamaha provides either an ASIO or CoreAudio driver for the console, I see no reason why this would work directly with Smaart 7 using the USB audio interface up to 16 channels I/O.
Tommy Peel
  • Longview, Texas
« Reply #2 on: October 17, 2013, 02:16:32 pm »
I appears that the Yamaha provided drivers are ASIO(Windows) and CoreAudio(Mac) so you should be fine.
Sent from my Nexus 4 using Tapatalk
Alfredo Prada
« Reply #3 on: October 17, 2013, 02:50:32 pm »
Please let us know if and how it works!
ron lavenski
« Reply #4 on: October 17, 2013, 06:03:48 pm »
i'll hook it up Friday and see,how it works may not report till next week(3 gigs this week end)and see if it works live with the persounus preamps
ron lavenski
« Reply #5 on: October 21, 2013, 07:35:45 am »
ok tried smart 7 with my o1v96i it worked, but u cannot use I tunes with it hooked up,still have a lot to learn with smart,only seen 1 class 2 hrs a way hopful to see some this fall/winter
Arthur Skudra
« Reply #6 on: October 21, 2013, 08:27:58 am »
What computer/operating system are you running?  Should be a simple setting in the operating system.
ron lavenski
« Reply #7 on: October 21, 2013, 07:25:55 pm »
i'm running windows 7 with I core 7 ,1.8 gigs
fedele de marco
    • https://www.facebook.com/fedele.demarco
« Reply #8 on: November 01, 2013, 11:25:02 am »
Yes...you absolutely can use 01v96i  as audio interface for smaart.
I use it very often for measures on the fly when I forget my card :-) and measures for multi-pending purchase of the octa capture.
You can use up to 16 microphones :-). the problem is that the gain of the pre jerky, not smooth. this is very annoying.  also to have a decent level you have to pull up to nearly full pre.
I solved the problem of gain in spurts, impotando as the DIRECT OUT PRE FADER, and then using the attenuator of the channel that provides + \ - 12 db
with the pre channel do the bulk of the layer, with the attenuator fine adjustments
you have button for reverse polarity and delay on  every channel.  and you can save scene  .-).
I'm asking if it is necessary to buy another interface for multimeasures...but then I think the size and weight of the 01v and the compactness and lightness of an octa capture  :-)
I apologize for my bad English
« Last Edit: November 01, 2013, 12:35:35 pm by fedele »
  • Old enough to know better
  • Audio Plumber
Posting Rules
« Reply #9 on: November 01, 2013, 12:43:14 pm »
Posting Rules
Page created in 0.184 seconds with 22 queries.
