Im thinking of going the sh46 route and i wouldnt always want to ground stack them. Would they work on lifts or are they to deep?
here is the sh46
http://www.danleysoundlabs.com/products/loud-speakers/synergy-horn/sh46/here is the sumner lift
http://www.sumner.com/sumner/sub/productb/downloadsa.26.7.26.0.0.0.htmlis this a bad idea in general or would it be fine?
The speakers would be well under the rated load.
236 lbs per lift plus whatever the frame would weight. Still under 500lbs per lift easily.
if this is safe. what if a 3rd speaker is added per lift and is still under the safe load but closer to 500lbs?
Im not going to get into the whole inside outside lift thing. I have seen that debated numerous times on here and i dont want to get into that if possible. These would be used inside.
Im thinking of going this route because it would be more easy set up, less time, and less weight than my current kf850 setup.
i would be saving around 700lbs (new weight minus old 850s. scaff lifts..) in the trailer. huge bonus.
thanks for reading.
