Pages: 1 [2] 3 4 5   Go Down
Author Topic: Generators  (Read 18538 times)
Kemper Watson
Re: Generators and Grounding - Intro and Definitions
« Reply #10 on: September 22, 2013, 08:43:27 pm »
It's all good.....
Especially if it saves someone's life.
Mike Sokol
« Reply #11 on: September 23, 2013, 11:12:18 am »
Everyone... Sorry if I overstepped my duties on my first day as moderator. Everybody deserves a Mulligan.
If it's safety related and important, then feel free to post any links here.
Mike Sokol
mike@noshockzone.org
www.NoShockZone.org
Jordan Wolf
« Reply #12 on: September 23, 2013, 12:46:30 pm »
No worries, Mike.  I'm sure it takes time to get used to that new-found power ;-)  Judgment calls are always the hardest.
Jordan Wolf
Dennis Wiggins
Re: Generators
« Reply #13 on: September 23, 2013, 01:27:34 pm »
Every time I do a gig with a generator I ask the provider "Where's the ground rod?" All I get is a funny look and the standard reply.  "It's grounded to the generator."
Please clarify. Shouldn't there be a copper ground rod attached to the generator that goes to earth?
Thanks
I found this example which explains when, and when not, to earth ground a generator.
http://www.electricity.state.mn.us/ccld/pdf/eli_notice_to_exhibitors.pdf
-Dennis
Mike Sokol
Re: Generators
« Reply #14 on: September 23, 2013, 04:27:50 pm »
-Dennis
I'm going to print this out at read it at length, but it seems like a good guide to generator grounding. I'll report back later once I absorb the entire piece.
Mike Sokol
www.NoShockZone.org
BobWitte
  • Soundman, Consultant, Love all things audio
    • Cascading Waters Audio
Re: Generators
« Reply #15 on: November 05, 2013, 01:45:30 pm »
How is the absorption going on this topic? Not that I am in any rush in Wisconsin as outdoor events with generators for us are over with.
Mike Sokol
Re: Generators
« Reply #16 on: November 05, 2013, 05:28:00 pm »
I should have some time to re-read this article by the weekend. Thanks for reminding me.
Mike Sokol
www.NoShockZone.org
Bob Leonard
  • Boston, MA USA
Re: Generators
« Reply #17 on: November 16, 2013, 08:27:32 am »
Mike,
I bought one of these kits last year, and still haven't installed it but will install it next weekend. Any opinion?
http://www.reliancecontrols.com/ProductDetail.aspx?31406CRK
BOSTON STRONG........
Proud Vietnam Veteran
Frank DeWitt
    • LBP DI Box
Re: Generators
« Reply #18 on: November 16, 2013, 10:21:27 am »
Mike,
I have always thought that those kits are a very reasonable logical way of connecting a home backup.  It let's you decide what ckts will be transferred to the generator and keeps you from overloading the generator.  A side benefit over a whole house transfer is you have other ckts to tell you when city power comes back on.
I have a Whole house transfer switch on the output of my main panel in the garage that feeds a sub panel in the basement. (I transfer the house power but not the garage.)  It works fine and it used the hardware I had on hand, but I must, using a flashlight, go to the basement and turn off the breakers to everything I don't want powered, then go the the garage and throw the main transfer.
Not to Code
Mike Sokol
Re: Generators
« Reply #19 on: November 17, 2013, 06:45:49 pm »
Mike,
That's the gold-standard way of connecting a generator to your house when the generator capacity won't run EVERYTHING. I've always been a little squeamish about the generator inter-lock kits which is basically a metal slide that only allows you to turn on the generator breaker once the incoming panel breaker is turned off. Not automatic, and may not be code compliant in your area: http://www.interlockkit.com/ilkitworks1.htm but certainly an inexpensive way to add a backup generator to your house power.
Mike Sokol
www.NoShockZone.org
Re: Generators
Pages: 1 [2] 3 4 5   Go Up
Page created in 0.047 seconds with 23 queries.
