Pages: 1 2 3 [4]   Go Down
Author Topic: Mic stands used for system measurements  (Read 13288 times)
Johnny Diaz
Re: Mic stands used for system measurements
« Reply #30 on: September 06, 2013, 11:03:06 pm »
Arthur,
When you are tightening the mic stand with the adapter to the nano stand at any point does it get tight enough that you can't turn it anymore?
Arthur Skudra
« Reply #31 on: September 06, 2013, 11:53:08 pm »
Arthur,
Yes, that's what it should do.  OK, to test things out thoroughly....
I have a 3/8-16 screw and matching nut in my collection.  I took the nut, and screwed it onto the 3/8-16 stud on the Nano stand...works perfectly, nice and snug.  I took the screw, and tested it in each of 10 adapters I have here in my collection of varying types, the screw threaded into the socket of these adapters perfectly.  Just to be sure, I tested each of the 10 adapters on the nano stand, each and every one of them can be screwed on and was tight enough to have a firm "stop" on the stud of the stand.
I took my caliper, and measured the inside diameter of the adapters I have here, they all measured 5/16" diameter with threads (or 0.314" if you don't have fractional inches)
I took my caliper, and measured the outside diameter of the stud on the nano stand, it measures a bit shy under 3/8" diameter (with threads).
I suggest you go find yourself a 3/8-16 screw and nut, and test it out for yourself.
Arthur
Johnny Diaz
« Reply #32 on: September 07, 2013, 03:04:09 pm »
Arthur
Arthur,
I will do that and report back.  Thanks.
Johnny
Johnny Diaz
« Reply #33 on: September 08, 2013, 01:54:54 pm »
Arthur
Arthur,
I found a nut and screwed it to the base of the nano stand and it fits snug.  When I screw a bolt to the adapter it never tightens fully and keeps turning.  I ordered a few more adapters and hopefully will have better luck.  The adapters don't seems to be made well.
Thank you for your efforts.
Johnny
Arthur Skudra
« Reply #34 on: September 08, 2013, 02:56:59 pm »
Arthur,
Johnny
Hi Johnny,
Yes, I suspected the adapters might have been poorly made.  There are several different branded ones to choose from at B&H, so pick another that hopefully will be better made, I must have bought the last "good" batch!!  Seems like adapters and mic clips are "hit and miss" lately in terms of quality.  I have one mic clip that doesn't even screw onto a mic stand because of a poorly tapped thready.  So do I buy a tap and re-thread it myself for $25, or do I buy a new clip?  Argh!
Cheers!
Arthur
Pages: 1 2 3 [4]   Go Up
Page created in 0.084 seconds with 23 queries.
