Author Topic: Ballroom Vision Install  (Read 1615 times)
Thomas Johnson
« on: August 27, 2013, 07:47:20 am »
Hi All, Great forum been lurking for a while
I look after the AV for a Hotel Ballroom and we are looking at getting a new vision distribution system installed.
We require 8 points on the floor level, 8 in the roof all via Cat6 and going back to a central patch back of house.
Not a vision guy and essentially wondering what the best format would be to use on the plates at either end of these runs. Happy to purchase the scalers and converters required.
HDMI? HD-SDI, DVI?
We do want to future proof as much as possible
Cheers for any help
Doug Fowler
  • Saint Louis, MO USA
Re: Ballroom Vision Install
« Reply #1 on: August 27, 2013, 07:55:26 am »
HDMI? HD-SDI, DVI?
Cheers for any help
Read the rules, fix your display name.
Thank you for your cooperation.
Brad Weber
  • Marietta, GA
« Reply #2 on: August 29, 2013, 04:23:18 pm »
HDMI? HD-SDI, DVI?
All the above and then some?
HDMI, DVI, DIsplayPort, etc. over UTP/STP/CAT solutions may be one option if you are dealing almost exlusively with a single source to a single destination.  But if you start looking at sending one input to multipel destinations or swithcing between destinations then it can get more complex due to having to address potentially different supported resolutions, EDID, HDCP, etc.
HD-SDI may be the simplest in terms of patching and distribution but part of that is because it does not deal with HDCP or EDID.  However, that also means not being able to support encrypted content and potentially having to do more manual configuration.
DVI and DisplayPort have the advantage of potentially handling both digital and analog signal formats, but you may have to deal with EDID and HDCP.  HDBaseT or AVB based system may also offer an option for handling multiple digital and/or analog signal formats, but you are then also into more complex devices and routing.
What it really comes down to is having to have a good understanding of the potential usage and your goals in order to make any specific recommendations.
Page created in 0.063 seconds with 23 queries.
