Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > AC Power and Grounding
Open AC Ground Problem
Brian Jojade:
--- Quote from: John Roberts {JR} on September 18, 2013, 01:27:35 PM ---You can buy outlet strips with GFCI built in... If we could depend on outlet grounds, they wouldn't have invented GFCI...
Use the force (technology) Luke...
--- End quote ---
GFCI offers different protection than ground. If you touch a hot wire and then a properly grounded connection, you'll get a shock. If you do the same thing with a GFCI circuit, it will see that the path is not going through the neutral line and trip. If you didn't have GFCI, the ground connection in that fault scenario makes it MORE dangerous.
Canute J. Chiverton:
--- Quote from: Brian Jojade on September 19, 2013, 12:08:55 PM ---GFCI offers different protection than ground. If you touch a hot wire and then a properly grounded connection, you'll get a shock. If you do the same thing with a GFCI circuit, it will see that the path is not going through the neutral line and trip. If you didn't have GFCI, the ground connection in that fault scenario makes it MORE dangerous.
--- End quote ---
This may be a stupid question but I am not an Electrical Engineer nor do I pretend to be one. I rather rely on one of you experts. Will a Furman Conditioner (Which is what I have in my Rack http://www.furmansound.com/product.php?div=01&id=PL-PLUSC) do the same job as the GFCI (The Home Depot Link above)? I don't have a problem getting the GFCI I think $30.00 is cheap.
John Roberts {JR}:
--- Quote from: Canute J. Chiverton on September 19, 2013, 12:23:01 PM --- This may be a stupid question but I am not an Electrical Engineer nor do I pretend to be one. I rather rely on one of you experts. Will a Furman Conditioner (Which is what I have in my Rack http://www.furmansound.com/product.php?div=01&id=PL-PLUSC) do the same job as the GFCI (The Home Depot Link above)? I don't have a problem getting the GFCI I think $30.00 is cheap.
--- End quote ---
No, if it did it would list that as a feature and require a reset button for the GFCI. It looks like a simple voltage spike clamp.
Jay Barracato:
--- End quote ---
I have a couple of simple plug in GFCI's that are the same brand as the cable Mike linked to. You simply plug them in to the edison outlet and then plug your power cables into them. They are the simplest way I have found to add GFCI to an existing circuit.
http://www.lowes.com/pd_145275-33536-30339011_0__?productId=1135923&Ntt=gfci
Mike Sokol:
--- Quote from: John Roberts {JR} on September 19, 2013, 12:39:51 PM ---No, if it did it would list that as a feature and require a reset button for the GFCI. It looks like a simple voltage spike clamp.
--- End quote ---
Correct.... The Furman is a spike/noise clamp unit, definitely NOT a GFCI, and it will do nothing to prevent electric shock if powered from an ungrounded outlet.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
