Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > Console Connectivity Solutions
Behringer X32
Jerome Malsack:
Behringer says 16 channels out and top 4, 13 to 16 are used by effects sends. So is my logic correct when I use the X32 rack connected to S16 with aes50 that I only have 4 outputs on the S16. 1 to 4. 5 to 8 is using the effects.
Is there something I missed in configuring the S16 and the patching? I would like to get all 8 outputs working on the S16. 1 threw 8 are working fine on the Rack. L/R out and 6 monitor sends.
James A. Griffin:
--- Quote from: Jerome Malsack on March 22, 2017, 08:13:04 PM ---Behringer says 16 channels out and top 4, 13 to 16 are used by effects sends. So is my logic correct when I use the X32 rack connected to S16 with aes50 that I only have 4 outputs on the S16. 1 to 4. 5 to 8 is using the effects.
--- End quote ---
You will be able to use all 8 outputs on the S16. You will still use Sends 13-16 for the effects, but those are intenal busses that don't patch trough the S16.
Jerome Malsack:
--- Quote from: James A. Griffin on March 22, 2017, 08:30:47 PM ---You will be able to use all 8 outputs on the S16. You will still use Sends 13-16 for the effects, but those are intenal busses that don't patch trough the S16.
--- End quote ---
Thanks will give another try after the weekend work.
Navigation
[0] Message Index
[*] Previous page
Go to full version
