Author Topic: Adding Fixture To GrandMA  (Read 5981 times)
Anoosh Kashefi
« on: June 19, 2013, 12:44:15 pm »
If the fixture I am looking for is not in GrandMA database already, how would I go about patching it?
Thanks ahead of time!
Josh Daws
Re: Adding Fixture To GrandMA
« Reply #1 on: June 19, 2013, 06:57:50 pm »
request a fixture profile from MA or make it up yourself on the console. this is definitely possible to do.
Anoosh Kashefi
« Reply #2 on: June 20, 2013, 12:47:52 am »
Hey thanks for the response. There is a way to do it, but you have to go in and literally map each channel and all! Pretty time consuming. I need it for a gig tomorrow, but I guess I will try asking MA for a profile, so thanks a ton for the tip!
Off to MA's site!
Josh Daws
« Reply #3 on: June 20, 2013, 08:22:37 am »
Off to MA's site!
it might be possible it has already been done. check their forums http://ma-share.net/ this is a great resource for MA.
and yeah depending on the fixture and how in depth i want to get with it. it can take about an hour to make a slightly detailed profile.
James Feenstra
« Reply #4 on: June 20, 2013, 06:51:44 pm »
Ma1 or ma2?
What fixture?
Provided there's a manual for it somewhere I can probably make it for you
Elevation Audiovisual
www.elevationav.com
Taking your events to the next level
Josh Daws
« Reply #5 on: June 20, 2013, 10:25:09 pm »
was gonna offer the same service if the OP came back to say they couldn't find it. rather share around the resources first. i have a crazy busy 4 days...lol
Ray Cerwinski
« Reply #6 on: June 20, 2013, 11:30:12 pm »
Based on his other post about how to address the fixtures, it sounds like he's using  Chroma-Q Color Splits.
Just patch them as a generic RGB fixture and make use of their "magic amber" function, or if you must have explicit control over the amber channel, there should be a generic RGBA fixture for you to use. If you need to use them "split", patch two fixtures for every one physical fixture.
Ray Cerwinski
Page created in 0.066 seconds with 23 queries.
