Pages: [1] 2 3   Go Down
Author Topic: "Official" Infocomm 2013 thread  (Read 11356 times)
Doug Fowler
  • Saint Louis, MO USA
« on: June 12, 2013, 01:13:12 pm »
Here ya go; updates here please.
Adam Wh3tham
  • Grand Forks, ND
Re: "Official" Infocomm 2013 thread
« Reply #1 on: June 12, 2013, 01:14:19 pm »
New Shure Microflex Wireless... Looks promising for my workplace actually.
http://www.shure.com/americas/conferencing/microflexwireless
I practice safe excursion on the weekends
Matt Vivlamore
  • Lab Lounge
    • https://www.facebook.com/MeerkatSound/
« Reply #2 on: June 12, 2013, 01:32:37 pm »
QSC's new 4 channel DSP amp; looks very interesting with being about to route the Output power 5 different ways.  However it looks like it only at the PLX/XTi level of amps with the USB connection.
http://qscmarketing.com/redefined
Mike Reigh
« Reply #3 on: June 12, 2013, 09:52:46 pm »
I'm not there, but the boss is.  New Martin MLA mini:
http://www.infocommshow.org/press_8903.asp#.UbklueeG2So
Craig Leerman
  • Global Moderator
  • Do Not Read This!
« Reply #4 on: June 15, 2013, 09:42:07 am »
A few items while I wait for a flight back home. In addition to the new Shure, Martin and QSC products mentioned:
DPA showed new podium mics that will be available at the end of the year.
Sennheiser showed a battery powered small speaker with built in mixer that accepts wireless receivers as well as wireless transmitters so you can wirelessly send the audio signal to the next speaker. They also showed a real cool flexible speaker that can wrap around stuff like truss.
Clear-Com has some new stuff including new belt packs for basic party line systems.
Danley had a bunch of new subs including a quad 15. They also showed a new bookshelf speaker called Caleb. It's 10' tall and is designed for stadiums.
Avid showed their new console.
Pivotec had the new Avid console running their stuff in the booth.
Line 6 has a new handheld with a different pickup pattern and also an active antenna splitter if you don't want to use the loop through jacks.
RF Creations Venue showed a compact and inexpensive (under $300 I was told) helical antenna for 2.4 band. Perfect for use with Line 6
Kaltman showed a new spectrum analyzer
Roland has a new A/V switcher geared toward web casting. They also said all their consoles now include Sonar recording for free.
I am missing a bunch but I have to catch a plane.
Craig
« Last Edit: June 18, 2013, 02:33:49 pm by Craig Leerman »
TechWorksReno.com
Facebook.com/TechWorksReno
Pinterest.com/TechWorks0492
duane massey
« Reply #5 on: June 16, 2013, 02:26:13 am »
Danley 10' bookshelf speaker. Good one, Craig.
Duane Massey
Houston, Texas
« Reply #6 on: June 16, 2013, 11:32:01 am »
It just depends on the size of the shelf  ;).
It is also "ipod ready".  You can drive it (as was demoed) with the output of an iphone or MP3 player etc.  No other amp needed.  All passbands were in parallel (no crossover-no eq etc).
Just use a "standard" 1/8" stereo plug to dual NL8 plugs (soon to be in a catalog near you)
One channel drove 54 drivers and the other channel the other 54 drivers.
« Last Edit: June 16, 2013, 11:44:05 am by Ivan Beaver »
John Moore
  • "learning the hard way sucks donkey kong"
    • Trinity Productions
« Reply #7 on: June 16, 2013, 02:37:03 pm »
ISP has a new zoned music system that uses Cat6 cable to power speakers and send signal over the same wires, and can be daisy chained up to 14 units depending on power/type, eve have a SUB that is power over the CAT6 cable. Great fidelity and features for retail or bar type installs. I was quite impressed !
http://www.trinityprosound.com 209-832-8023
DEALER:Dealer for Yorkville, EV, QSC, RCF, Danley Sound Labs, VTC, Allen & Heath, Ashly, Denon,  Audix, One Systems, Beyerdynamic, Presonus, K&M, Ultimate,  Trusst, Road Ready, Gator, Radial Engineering, Turbosound, dB Technologies, RCF, American Audio,  Rapco, CBI Cables, ADJ, Chauvet, Blizzard, Furman, Shure, Tascam, Elite Screens,  BenQ, Midas, Digico,  and many many more...
Cailen Waddell
« Reply #8 on: June 16, 2013, 11:30:06 pm »
Any specs on that yet?  Clearly I need bigger bookshelves...
RYAN LOUDMUSIC JENKINS
    • Az Concert Sound Solutions
« Reply #9 on: June 17, 2013, 12:04:10 am »
Hmmmm, a line array loaded into a single large horn.   Patiently Awaiting white paper.
Pages: [1] 2 3   Go Up
Page created in 0.056 seconds with 22 queries.
