Pages: [1] 2 3   Go Down
Author Topic: 2 horns is this possible?  (Read 8806 times)
Mohit Palesha
« on: June 10, 2013, 12:21:46 am »
I wish if i can use two 1" compression drivers with selenium 14 - 25 horn fitting them side by side horizontally.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=264-315
I will wire the tweeters in series so that i can get 16 ohms impedance.
The reason of doing this is to improve reliability of system.
Is this possible?
waiting for guidance,
Jeff Bankston
Re: 2 horns is this possible?
« Reply #1 on: June 10, 2013, 01:09:29 am »
if reliability is the concern buy a Radian 475PB driver. i cant garuntee you wont blow it up but its a top of the line driver. there are Y adapters made to put 2 drivers on one horn.
« Reply #2 on: June 10, 2013, 06:10:19 am »
Depends on what you call "reliability".
Putting them in series-if one fails, then the other will stop working.
Parallel would be a better way for  reliability.
Placing the 2 HF side by side will result in cancellations. notches in the response etc.
This will often lean to you turnt hem up (pushing htem harder), which puts more strain on them.
You would do MUCH better by using a SINGLE better quality driver-sound quality-sound output-reliability etc.
With audio-the FEWER drivers used-the better.
Less is more
paul bell
« Reply #3 on: June 10, 2013, 08:29:59 am »
Less is more
I'm with this guy^
John Halliburton
« Reply #4 on: June 10, 2013, 09:12:53 am »
I'm with this guy^
I agree with Ivan and Paul too.  I would also recommend a larger horn-overkill is not a bad thing.
I'd rather go with a B&C or BMS driver too-the Radian is a great sounding driver, but my experience says the B&C and BMS are more reliable.
John
Stu McDoniel
  • Central Wisconsin...USA
« Reply #5 on: June 10, 2013, 10:11:33 am »
Is this possible?
This appears to be a 45x45 degree horn.  If you are trying to get more horizontal coverage by doing
the side by side horn thing then why not go with what the guys suggest and get ONE quality compression
driver and mount it on a horn with more horizontal dispersion?
I am only making an assumption of coverage because of your choice to place two horns next to each other horizontally.
If you insist on using two horns, and compression drivers then place them vertically next to each other.
Brook Hovland
    • DiA Events
« Reply #6 on: June 10, 2013, 06:58:07 pm »
Ivan hit the nail on the head.
However, IF you already own the Selenium drivers and want better reliability, put a quick change hatch on the back of your speakers to exchange 'em quicker!  :D
Mohit Palesha
« Reply #7 on: June 12, 2013, 01:23:21 am »
I came across following dual horns with peizo tweeters.
What they have done to overcome the problem as mentioned above.
paul bell
« Reply #8 on: June 12, 2013, 02:24:04 am »
Nothing. They don't sound very good.
Mohit Palesha
« Reply #9 on: June 12, 2013, 11:57:15 am »
I know that they don't sound good as they are peizo tweeters.
I just want to know whether they are able to get the dual horn problem solved due to their construction.
Pages: [1] 2 3   Go Up
Page created in 0.065 seconds with 22 queries.
