Author Topic: Speaker Cable  (Read 4311 times)
Zachary Zimmerman
  • Shenandoah, VA USA
Re: Speaker Cable
« Reply #10 on: May 22, 2013, 10:52:47 pm »
As just mentioned you could use speakons wired with four conductor cable and double up on the connections.
That could get confusing if the cabinets or amps racks got mixed in with a bi-amp wired NL4 system.
How would it get confusing if you just used them as is only the pin 1 would actually carry power the other would never be used unless the box and amp was setup for biamping
Hey Y'all watch this
Mike Caldwell
  • Covington, Ohio
Re: Speaker Cable
« Reply #11 on: May 22, 2013, 11:14:13 pm »
If inside the cabinet the speakons were wired say 1+ 2+ paralleled together as well as 1- 2-. The mating amp rack would be wired the same on the output panel.
Getting cabinets or amp racks mixed up could cause problems.
I do know of systems where they are wired like that on the subs to take advantage of the extra copper in a four conductor NL4. A slightly different take on that is bi-wiring a double driver sub box, each speaker on it own pair of cables back to the amp rack.
Zachary Zimmerman
Re: Speaker Cable
« Reply #12 on: May 22, 2013, 11:18:11 pm »
Right I have never heard of a sub that actually does that now we do have at work special breakouts that do that externally not in the cabinet itself
Yes I see we're you see the problem most amps primary nl4 has both channels on it
paul bell
Re: Speaker Cable
« Reply #13 on: May 23, 2013, 07:27:20 am »
Powersoft amplifiers double up on their output NL4 jacks. IOW, 1+ & 2+ are strapped together, same for the - terminals. I know at least some BASSMAXX cabinets were wired to match this wiring convention.
You can find 10/4 SJ cord if you search around the web long enough. It'll fit a NL4 plug.
My longer NL4 cables (25 foot and longer) are wired with 13/6 speaker cable. It takes some effort, but using two of the 13 gauge conductors per pins 1 effectively doubles it's current capacity. This is commonly done in electrical installations. Doubling a wire makes it's gauge size two wire sizes larger. EG: two 14 gauge conductors (15 amp capacity each) would equal one 10 gauge wire with a capacity of 30 amps.
As far as "helping" the damping factor of amplifiers, it really only matter with subs. The higher the frequency, the less the effect of copper losses.
« Last Edit: May 23, 2013, 07:31:06 am by paul bell »
Johnny Diaz
Re: Speaker Cable
« Reply #14 on: May 23, 2013, 08:20:50 am »
Paul,
So your saying that on the powersoft amps you need to use a 4 conductor wire.  So I'm assuming that on the the amps output the 4 conductors are independent and on the sub input the positive terminals are connected to pin 1 and the negative terminals are connected to pin 2.  Is my understand correct?  So if were to use a 2 conductor cable on the amps output instead of 4 what would happen?  Less power?
Re: Speaker Cable
« Reply #15 on: May 23, 2013, 12:45:41 pm »
Well in theory if you load it down to 2 ohms with a 12 awg cable you are definitely losing some power and the damping factor is being affected.  Real life may be another story.
Repeat after me:  "damping factor is a bullshit specification."
Most of the major sound providers in the USA use #12 (or multiple conductors to equal that size) for speaker cable runs that total over 100'.
Paul Dershem
  • San Diego, CA
Re: Speaker Cable
« Reply #16 on: May 23, 2013, 01:42:39 pm »
In other words, folks who obsess about damping factor are "all wet."
Live without pretending
Love without depending
Listen without defending
Speak without offending.
John Chiara
Re: Speaker Cable
« Reply #17 on: May 23, 2013, 05:29:42 pm »
I have 12 horn loaded subs and they are ALL wired that way, both to double the copper but more importantly for testing each driver individually.
Caleb Dueck
Re: Re: Speaker Cable
« Reply #18 on: May 23, 2013, 07:09:41 pm »
Repeat after me:  "damping factor is a bullshit (amplifier) specification."
But is is a cabling consideration for installs, or sometimes an application for Powersoft K-DSP amps.
paul bell
Re: Speaker Cable
« Reply #19 on: May 23, 2013, 07:36:46 pm »
Paul,
Hey Johnny,
No, the Powersoft K series amplifiers have an NL4 jack for each channel. In each jack, both positive pins are linked as are both negative pins. You can use pins one only, pins two only or both for additional current carrying capacity. This is for the amplifier in stereo mode:
Re: Speaker Cable
Page created in 0.07 seconds with 23 queries.
