Author Topic: par bulbs blowing out too early  (Read 5982 times)
John Hyun
« on: May 06, 2013, 02:40:23 pm »
my friend's church is having some lighting issues.  they have par64 and par56 fixtures for their stage light connected to dimmer and console.  some of the lights were blowing out a couple of months after replacing. I am wondering what the issue might be and where to start looking.
thanks!
TJ (Tom) Cornish
  • St. Paul, MN
Re: par bulbs blowing out too early
« Reply #1 on: May 06, 2013, 02:46:00 pm »
thanks!
Look to bulb quality and rated lifetime.  This is one case where buying brand name is worth it - Osram/Philips vs. off-brands makes a difference.  Also, there are likely different bulb lifetimes to choose from.  For a permanent install, long-life bulbs are your best bet, though they'll be a little dimmer and yellower than short life bulbs.
About the only thing else to look at is if your building is over voltage. 115v bulbs are designed assuming a 120v supply and 5 volts of loss through the dimmer circuitry and wiring.  If you're starting at higher than that or if you have a particularly efficient dimmer, you may be getting more voltage at the socket than the bulb's nominal life is rated for.  The solution is to get 120v bulbs, 130v bulbs, or leave your master dimmer at 95%.
duane massey
« Reply #2 on: May 06, 2013, 06:06:44 pm »
Are you using par lamps or the "raylight" kits with DYS lamps?
Duane Massey
Houston, Texas
John Hyun
« Reply #3 on: May 06, 2013, 06:09:57 pm »
par lamps
John Hyun
« Reply #4 on: May 06, 2013, 06:16:34 pm »
thanks tom.
long life bulb...2000 hours?
Their par56 bulb says 300w/120v
Their par64 bulb has nothing on it.
Is there a way of knowing if it was either a 500w or 1000w? the watts determine the overall brightness of the fixture, right?
Milt Hathaway
    • http://www.fitzcosound.com
« Reply #5 on: May 06, 2013, 06:28:14 pm »
Look into the lamp through the front lens. If you see a bare filament, then it is 500W incandescent. If the filament appears to be inside smaller long thin 'bulb', then it is a 1000W quartz.
Milt
FitzCo Sound, Inc.
Midland, TX
James Feenstra
« Reply #6 on: May 07, 2013, 12:54:14 pm »
most par lamps are rated for about 1/6th of that
If you're getting 1000+ hours out of any par lamp, you're doing pretty good
At the venue I used to work for I was changing lamps every 3-4 months when we were running 4+ nights a week.
Elevation Audiovisual
www.elevationav.com
Taking your events to the next level
John Hyun
« Reply #7 on: May 07, 2013, 09:19:53 pm »
i will give these a try
http://www.bhphotovideo.com/c/product/835502-REG/Sylvania_14932_500PAR64_MFL_Lamp_500W_120V.html
on paper it states 2000hours...real world application will be definitely less than that...
  • Old enough to know better
  • Audio Plumber
« Reply #8 on: May 07, 2013, 09:37:49 pm »
Running lights 10% below rated voltage raises the life something like 10x. Check your building voltage to make sure you aren't a little over voltage, which will lower the life a lot.
Josh Daws
« Reply #9 on: May 07, 2013, 11:46:38 pm »
don't try those...from looking at the ceramic on the picture they seem like the aluPAR series from osram...you want the other one. i can't remember the specific order code..and osram hasn't listed it on their site. if i remember tomorrow to get the order code i will. but definitely make sure that it is a glass Par59 and not the aluPAR...the lamp life on those are not that great at all.
Page created in 0.074 seconds with 23 queries.
