Does anyone know of a dummy load that is available to do some amplifier testing? I want to run my system at full tilt for a bit to balance out generator draw and make sure there are no issues. I would need 8 4ohm loads. 4 capable of 2500 watts and 4 capable of 775 watts.
Although Ivan's suggestion is great if you do this type of thing regularly, you probably already own space heaters, toasters and maybe a pizza oven, and can probably borrow whatever other loads from others to add up to what you need.
Since the average heating power of music is only about 1/10th (or less) of what a 120 volt 60 Hz continuous sine wave signal is (USA power), you won't need as much "load" as the amplifier peak power can provide, just use heating elements that are around the load value you want.
A 1500 watt heater space heater is 9.6 ohms, the old 4 slice AMC toaster is 10.6 ohms.
Par 64 lights work OK too, but the impedance changes quite a bit as they start to glow.
Fun to watch them light up with the beat, and they actually make some audible sound too.
