Author Topic: Y-Splitter or Jumper Question  (Read 1931 times)
James Frattali
« on: April 12, 2013, 08:31:39 am »
I have a small sound system for a band.  I am running a mono monitor setup powering four floor monitors, connected in parallel pairs at 4 Ohms per pair.  These are being powered by a single CS800 amplifier - one pair connected to amp channel A and one pair connected to amp channel B.  I am trying to decide between two ways to connect the mono monitor signal to the amp's two channels.  Method 1 - I can run a single balanced XLR cable from the monitor EQ output to the channel A input of the CS800 and then use a jumper between the amp's channel A input and the channel B input (Peavey calls this "Full Range Mono" in their manual.  I believe the two amp inputs, when connected this way, are in parallel and Peavey even refers to it as a Y-cord connection.  Method 2 - I can use an XLR Y-splitter right out of the monitor EQ output and then run from the two Y-Splitter outputs to the amp's channel A and channel B inputs.  Is there really any difference in these connection methods?  Which method is better?  What are the pros and cons of each?
TJ (Tom) Cornish
  • St. Paul, MN
Re: Y-Splitter or Jumper Question
« Reply #1 on: April 12, 2013, 09:16:43 am »
Please change your username to be your full real name, per forum rules.
Scott Harris
  • Subwoofer forum
  • Worcester, MA
    • Running Sound
« Reply #2 on: April 17, 2013, 08:06:40 am »
For future reference, this would get more attention in the lounge.
Signal wise I would think there is no difference.  In real world use I would connect to a single channel then jump it to the other.  This removes any possible problems associated with a Y cable.
Page created in 0.017 seconds with 19 queries.
