Author Topic: Getting reference signal back in  (Read 3882 times)
Derrick McDonald
« on: March 25, 2013, 03:20:35 pm »
I kinda always thought that when using itunes for reference music that the signal could be routed into Smaart without having to run an output cable into an input on your i/o.  Is this correct?  I've been messing with my system for a learning experience and if I assign my reference signal from my core-audio input, it just makes my computer's onboard mic the reference.
I'm on Smaart 7.4, macbook pro, motu ultralite i/o....
Outputs 1-2 are going to my home stereo inputs
Motu input 1-2 are my measurement mics
I know I must be missing something obvious, please help
edit: I can use it coming out of my motu and then going to one of the motu's inputs.  There has to be an easier way
« Last Edit: March 25, 2013, 04:41:29 pm by Derrick McDonald »
Arthur Skudra
Re: Getting reference signal back in
« Reply #1 on: March 25, 2013, 05:05:55 pm »
Nope, you will need to use an external loopback cable taking the output of your device, and feeding it back into one of the inputs.
Nope, only Smaart's signal generator can loop back internally if you are using an appropriate interface in which the inputs and outputs are synchronized.  But even then, iTunes will not be able to be internally looped back into Smaart.
Brian Larson
« Reply #2 on: March 25, 2013, 06:17:12 pm »
I've never used SMAART but if you're on a Mac you can download a small application called Soundflower which allows you to route audio from one application to any other. Not sure if this would work for you but it's worth a look.
Malcolm Macgregor
« Reply #3 on: March 26, 2013, 10:16:44 pm »
Putting it to an output and then back to an input solves timing (and perhaps conversion) issues so it's actually the best solution unless you really need the extra input.
Derrick McDonald
« Reply #4 on: March 27, 2013, 11:58:30 am »
excellent, thanks
karel will
« Reply #5 on: April 20, 2013, 04:04:57 pm »
Hi Derrick,
Check out some program called Jack OSX: http://www.jackosx.com
It lets you route audio from any program to any program on your Mac.
Disclamer: I haven't used it myself.
Good luck!
Charlie
Arthur Skudra
« Reply #6 on: April 21, 2013, 02:11:18 pm »
Hi Derrick,
Good luck!
Charlie
Again, the issue is more to do with timing that just routing outputs to inputs.  Software solutions like jack osx or soundflower work ok for simple recording work, however fall apart for dual channel FFT work where synchronization of signals are critical.
Page created in 0.055 seconds with 22 queries.
