Author Topic: So, when can I say "I am competent with electrics?"  (Read 7529 times)
James Feenstra
Re: So, when can I say "I am competent with electrics?"
« Reply #10 on: March 14, 2013, 09:02:58 pm »
Rafi,
I, too, would like to be able to list that on my resume.
You might want to look into ETCP/ESTA training for electrical.
etcp is more about liability than it is about actual knowledge. The problem with holding an etcp card is that in event of an accident on a show you're involved in you automatically become liable, even if you are not directly in charge.
I hope you have good insurance before getting your ticket.
Elevation Audiovisual
www.elevationav.com
Taking your events to the next level
Jordan Wolf
« Reply #11 on: March 14, 2013, 10:01:59 pm »
Interesting...didn't know that.
Jordan Wolf
Zachary Zimmerman
  • Shenandoah, VA USA
« Reply #12 on: March 14, 2013, 10:19:35 pm »
The liability here is what u should be worried about. There are a lot of us that tie in and we are taking a risk when we do.
Hypothetical situation lets say joe is not a certified electrician and he's the main sound guy who always does the tie ins when there's not a house electrician. But on this one show he ties in like every 100 times before but this time there's a bolt loose in the disconnect. When the disconnect is engaged the bolt falls out and welds itself between 2 phases and the breaker does not trip because its old and the feeder coming to the disconnect gets hot and catches fire.
Well it's nothing joe did but joe was not an electrician well no Lawyer will be able to disprove the fact that joe was not an electrician. Therefor joe will be paying for the damage and liable for any injuries.  Even if an investigation which will be done may prove that it was not joes fault.
Hey Y'all watch this
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #13 on: March 25, 2013, 03:30:25 pm »
which is why Brian NEVER does tie-ins.  ever ever ever.
brian maddox
bdmaudio@gmail.com
Brian Larson
« Reply #14 on: March 25, 2013, 06:44:15 pm »
So, what if you plug an extension cord into a faulty outlet in a bar and the place burns down. Are you just as liable? Is the difference only the type of connector? (Cams vs. Edison)
Not trying to dispute you, just wondering where the line is drawn.
Josh Daws
« Reply #15 on: March 25, 2013, 07:24:05 pm »
yes you are still liable regardless of what AC Cables/Distro you use(expecially if its your power distribution) are you are technically are providing power. At least that is my understanding of it.
also as a side note (as i have learned my lesson), you should always carry a GFI outlet tester with you, and before you plug something into an outlet to ensure that the outlets are all good! it won't tell you inproper voltage, but will sort out incorrect wiring.
James Feenstra
« Reply #16 on: March 25, 2013, 07:31:44 pm »
it depends where the fault/start of the fire is.
if it's your cable, you're liable....if the bar's wall outlet is faulty and causes the fire, they're liable.
if you're tying in tails directly the fault is generally on whoever did the tie in. if you're just plugging in to existing cams it's the same as plugging into a wall outlet.
www.elevationav.com
Zachary Zimmerman
« Reply #17 on: March 25, 2013, 07:43:15 pm »
Usually when I hear the term tie in used to me it means that a disconnect or panel has been opened and individual conductors (tails) have been inserted and clamped in the lugs.  Big differance in connecting an Edison or even actual cams to a cam panel.
See the difference
Picts from PSAV
And meltric
« Last Edit: March 25, 2013, 07:44:49 pm by Zachary Zimmerman »
Craig Leerman
  • Global Moderator
  • Do Not Read This!
« Reply #18 on: April 08, 2013, 04:14:33 am »
Rafi,
The correct term for the resume would be "Entertainment Electrician" or "Stage Lighting Technician" and not simply "Electrician".  The term Electrician would imply that you work on residential or commercial power systems.
I would think that it would take more than a few years working in a theater or union for one to gain enough knowledge of the electrics department to be able to understand the majority of the job.
As for the ESTA certification, its not for beginners. It is geared more toward seasoned pros who want or need some acknowledgment of their skill set for their job (or a better job).
I'll second the Entertainment Electrician course and book from Richard Candena.
TechWorksReno.com
Facebook.com/TechWorksReno
Pinterest.com/TechWorks0492
Page created in 0.079 seconds with 22 queries.
