Author Topic: Video Hard Disk Recorder  (Read 3105 times)
Glen Kelley
  • El Paso, TX
    • The University of Texas at El Paso
« on: March 08, 2013, 01:22:42 pm »
I have a speech therapy lab on our campus that has asked us to provide video recording in their therapy rooms. Currently, audio is being recorded onto Tascam HDR1's. These will remain as backup. I have looked at a few options, but just don't have enough experience with hard disc video recorders to know where to look.
The requirements:
1) Standard Definition
2) 60Gb minimum storage
3) Easily editable file formats (uncompressed video is not necessary, but the users need to be able to "snip" portions of the recordings out to use for demonstration and/or research)
4) IP control
5) IP file access
The "nice to haves":
1) remote access to view live video
2) automatic .ftp or upload of video when the recording is stopped.
3) 1 ru
I have looked at products from Sony and DataVideo. Are there other products that any of you have used, or had good luck with? I am not interested in "security" type recorders. In my experience, these devices generally do a poor job of recording and syncing audio with the associated video. Since this is a speech therapy lab, the audio and video sync is very important! That said, if you have used something like this that meets the listed requirements, and it does a good job, feel free to mention it.
If you have questions regarding the application or need clarification on any of these points, ask away!
Thanks!
  • Old enough to know better
  • Audio Plumber
Re: Video Hard Disk Recorder
« Reply #1 on: March 08, 2013, 03:42:48 pm »
The requirements:
4) IP control
5) IP file access
3) 1 ru
Thanks!
Pretty much the only video recorder I've seen used for the last couple of years is the AJA Ki Pro. There are several versions, but I mostly see is the original.
It is easy to take the drive out of the recorder and attach it to the edit system via Firewire, and drives are reasonably priced.
Sean T. Hayes
« Reply #2 on: March 09, 2013, 10:56:16 pm »
I will second the Ki Pro. These are in high demand in our rental inventory. The best option we have found yet.
Sean
Sean T. Hayes
A lack of planning on your part does not equal an emergency on my part.
Glen Kelley
  • El Paso, TX
« Reply #3 on: March 15, 2013, 02:24:44 pm »
Sean
Thank you Mac and Sean! This looks like a good solution. The API is a bit daunting, but comprehensive.
It surprises me how spendy video hard-disk recorders are!
Sean Hayes
« Reply #4 on: March 15, 2013, 06:13:29 pm »
They are not cheap, but we use them because we can record in almost any format which is a big need for what we do in the rental world. There may be a less expensive option out there that only does the format you need, but Ki Pro is considered standard by most in the industry.
We have also looked into Black Magic's Hyperdeck. We were stuck on back order for too long and ended up cancelling our order. Must be having sourcing issues.
Good Luck,
Sean
Sean T. Hayes
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #5 on: March 15, 2013, 06:21:52 pm »
Good Luck,
Sean
We've got a couple of the HyperDecks at my church.  They work great for what they are so long as you're already using SDI with embedded audio, which we are, and already have a postproduction NLE workflow, which we also do.  They've yet to implement the network control and other things that were promised, but these weren't critical for our needs.  I use SSDs and record everything in 720p using ProRes HQ.  no complaints so far...
brian maddox
bdmaudio@gmail.com
Kyle Malenfant
« Reply #6 on: April 24, 2013, 11:09:34 pm »
What about the KI Pro Mini?  Does it function similarly as accepting an output from my switcher (HD-SDI) or does it have to be mounted and record directly from the camera?
Mike Brown
« Reply #7 on: June 07, 2013, 11:35:01 pm »
The requirements:
4) IP control
5) IP file access
3) 1 ru
Thanks!
You may want to look at something like the NCast systems.  They offer some really cool capabilities.
Page created in 0.062 seconds with 24 queries.
