Author Topic: yamaha dme 64n : how to label outputs ???  (Read 1247 times)
raulribeiro
« on: March 04, 2013, 03:31:04 pm »
I to all. New user, big question:
I want to know how to label outputs in slot out editor,yamaha dme64n.
Firmware I'm using :V3.8
Thank you in advance , by the way is urgent and I search again and again for an answer everywhere.
Brad Galvin
Re: yamaha dme 64n : how to label outputs ???
« Reply #1 on: March 05, 2013, 06:20:56 pm »
Right click the output box on the designer (must be in design mode), and at the bottom you should "properties". Click that, then click "edit I/O Port Label"
That lets you label them within the designer page, but I do not believe that you can see the labels when you pull up the meter page that you posted.
good luck
BG
Brad Galvin
Freelance Audio Engineer & System Tech
raulribeiro
« Reply #2 on: March 06, 2013, 01:40:19 pm »
good luck
BG
THANK YOU.  Just did it, many thanks.
Page created in 0.044 seconds with 22 queries.
