I've been asked to help a friend install 6 community R.25 200W/70v speakers in a small gymnasium. He wants to power them with a Crown 1160 MA 180 W/70v 4 channel in 1 out mixer amp. I am questioning him on adequate power . I s it enough? Since it is 70v does it even matter?
Yes, it matters at least as far as the amp needing to be able to drive the connected load.
They have six speakers with selectable 25W/50W/100W/200W 70V taps. And an amp rated at 160W (at 1kHz) into 70V. However, you are probably planning on reproducing more than just a 1kHz signal which means the amp may be capable of a bit less than 160W with wider bandwidth content. And there will be some losses in the cabling to the speakers, through the transformers, etc. Combine those and you seem to be just a bit on the low side even with the speakers at the lowest 25W tap. I won't go as far as to say it won't work but if I were designing the system I would look at a larger amp.
It may also be worth noting that you would typically provide a high pass filter and some equalization for those speakers.
