Pages: [1] 2 3  All   Go Down
Author Topic: Deciphering projector stats  (Read 6356 times)
Gerry Seymour
    • My Professional Website
« on: January 27, 2013, 10:08:23 pm »
Long time away, and now I'm posting in the AV section instead of the Lounge...
I've been digging through the myriad available portable projectors for conference room-style training use (follow-along computer demonstrations, PowerPoint, etc.), and I can't figure out what I should really be looking for. I have a loaner for now, but it's pretty low-end, and doesn't look good under normal lighting in those places.
I've visited websites to look for answers, but I've seen info I can't believe is true (some say 5,000 lumens or more if ANY ambient light, for example), as well as a large amount of info I don't really know the importance of (contrast ratio, which I understand is probably more determined by ambient lighting than the projector).
So, to the experts out there, if you were choosing a portable (will have to be able to carry on planes at times) projector, what would you look for. Ideally, I'd like to get answers in two categories: relatively low-cost (to replace the loaner pretty quickly) and what you'd prefer if cost weren't really much of a concern.
Follow-up: It looks like LED isn't anywhere near ready for this kind of application (the brightest I could find was 700 lumens, I think). Is there any expectation of higher-output portable LED projectors in the next few years?
Gerry Seymour
Professional Trainer and Speaker
(with lighting/audio experience)
anything that moves will eventually die
anything that doesn't move is probably already dead - James Feenstra
Jordan Wolf
Re: Deciphering projector stats
« Reply #1 on: January 27, 2013, 10:33:39 pm »
Gerry,
I know you didn't ask for a particular product, but this one has worked well for us for the types of meetings you seem to be doing
The NEC NP-M311W works very well in "typical" ambient light conditions of most meeting spaces that would require (from my experience) no more than a 7ft. wide screen for the types of material you're presenting.
It's native widescreen (16:10 @ 1280x800) and has an HDMI input for futureproofness™.  The built-in speaker is admirable for what it is…if you need more output for the room, you probably also need a larger screen and projector.  Make sure to turn the auto-keystoning "feature" OFF.  One of my favorite features is the lens cover - it knocks down the lamp output when used as a shutter, so you're not left with just digital black on the screen.
« Last Edit: January 27, 2013, 10:36:43 pm by Jordan Wolf »
Jordan Wolf
Gerry Seymour
« Reply #2 on: January 27, 2013, 11:58:38 pm »
Gerry,
I'll take a look at that one. I guess I wasn't clear - I actually do want to hear some actual recommendations like this, as well as advice on what stats really matter (and at what level).
Yes, in my experience, a 7'-wide screen is about as large as one can expect to go with a portable projector, and as large as one would need in a situation using portable equipment.
A side note: it makes complete sense that projectors should follow the computer display trend and go to widescreen resolutions. However, in my experience, that's a sub-optimal setup for most presentation uses. If I have to use PowerPoint (or similar), I rarely have long enough bullet points to use the additional width wisely. If I'm demonstrating software, a similar issue exists (unless it's software with lots of tool docks, like illustration software). The issue is that I'm still working with 7' of width, regardless of the ratio. With 16:9 (and other wide formats) that means my screen is much "shorter" than if I use 4:3 resolutions.
So, I usually end up going dual-display, setting the projector as the second monitor at a 4:3 resolution, and getting a bit more real estate on my screen.
Gerry Seymour
Brad Weber
  • Marietta, GA
« Reply #3 on: January 28, 2013, 09:29:19 am »
It is really all application driven and some factors may be:
Format/Resolution - What type of content will be displayed?  Do the potential applications involve HD content?  Will the use be primarily video or computer graphics or some mix?  These kind of factors may indicate what format (4:3, 16:10, 16:9, etc.) and resolution (1024x768, 1280x800, 1920x1080, 1920x1200, etc.) are most appropriate.
Brightness and Contrast - As you mentioned, what really matters is the image contrast ratio, how black and white in the projected image relate to one another with the black level often set by the ambient light in the room rather than by the projector.  There is actually a Standard for recommended image contrast ratios for several general applications but that is much more establishing goals than defining what may be acceptable, ironically recommended image contrast information is often presented using projected images with contrast ratios lower than what are being suggested.  But basically, the larger the image and brighter the room, the brighter the projector required to maintain a usable contrast ratio for a given type of content or application.  And with modern projectors the contrast ratio for the projector itself is rarely a significant factor except in the darkest environments and most critical applications.
Throw Distance and Lens - How far can the projector be from the screen to create a certain size image or what size image can be created from a certain location?  If you have typical image sizes and/or screen and projector locations then you want to make sure the projector supports those.  And where you don't have known conditions you may want a projector and lens that are as flexible as possible in the locations and image sizes supported.
Inputs - What signals (composite video, VGA/RGBHV, HDMI, DVI, SDI and so on) do you need or want the projector to support?
Lens Shift/Keystoning - It can often be necessary to locate the projector at something other than the ideal location relative to the projected image, what variation from the ideal vertical and horizontal location needs to be accommodated or how much value does supporting a larger variation offer?  Lens shift is actually using the optics to allow moving the projected image up and down or left and right while keystoning with digital projectors is usually digitally manipulating the image to compensate for keystoning that occurs.
Noise Level - In some applications the noise level from the projector can be a factor.
Multiple Lamp Operation - Some projectors use a multiple lamp system and many of those allow that to be employed to provide redundancy or longer life at a lower output.  I like these in situations where a show might stop with a dead lamp but could continue with a slightly dimmer image.
Lamp Life - How long do lamps typically last?  What is often misunderstood is that the values quoted are typical useful lives with the OEM lamps and aren't necessarily when lamp failure is expected, however some projectors start putting up messages, etc. when the lamps reach the end of their expected life.
Filters - Most projectors have filters that need to be kept clean for proper operation and longest life.  Some projectors have self-cleaning filters or filter cartridges that automatically change the portion exposed.  If there are filters, how they are accessed, etc. can become a factor depending on the location and accessibility of the projector.
Jordan Wolf
« Reply #4 on: January 28, 2013, 09:54:37 am »
I'm going to go alongside Brad's post, point-by-point, to demonstrate how I feel the NEC projector I mentioned, and any similarly-spec'd unit, would rate for the OP's use.
Format/Resolution - Yes, the unit is 16:10 native, but you can certainly change some settings to show a 4:3 A.R.  There will be digital black on the sides, which may or may not be an issue.
Brightness and Contrast - My first-hand experience with this projector has been in meeting rooms that max out at around 40ft. deep by 32ft. wide.  With house lights at 100%, all text and lines/outlines were sharp and well-defined from at least 2/3 of the way back into the space on a 7ft. tripod screen in 4:3 format.  Most meeting rooms have space in the back for luggage, water stations, etc., so it's not unlikely that seating would be closer to the front than that.
Throw Distance and Lens - Since the OP seems to be knowledgeable, I would assume that - like me - he would want to arrange for optimal placement of the projector (not usually an issue for small- to medium-sized spaces.  For a 7ft. screen, 12ft. of throw gets you in the middle of the lens' zoom range.
Inputs - Adding HDMI, as well as having 2 VGA inputs, allows for a more-futureproof unit.  A USB Wifi transceiver can also be added, allowing for remote control and networking.
Lens Shift/Keystoning - There is only vertical keystoning, and no cornerstoning ability.  However, the two rear feet are fully adjustable, and the front main foot, centered, allows for small changes in height.  With
Noise Level - 35dB is what the manual claims (what freq. range, weighting, etc. I'm not sure…maybe there's a spec. for those things, I just don't know).
Multiple Lamp Operation - Only 1 lamp necessary, and they're compatible from the older models of the projector.
Lamp Life - That depends on how long you run it - in my previous post, I mentioned how sliding the lens cover dims the lamp brightness, which helps increase lamp life when you don't want an image up, but need immediate access to use the projector if needed.
Filters - All the NEC portable projectors I have used have filters that are easily accessed and cleaned.  The alerts can also be reset from the menu without digging through too many submenus.
Jordan Wolf
Brad Weber
  • Marietta, GA
« Reply #5 on: January 28, 2013, 03:31:10 pm »
A side note: it makes complete sense that projectors should follow the computer display trend and go to widescreen resolutions. However, in my experience, that's a sub-optimal setup for most presentation uses. If I have to use PowerPoint (or similar), I rarely have long enough bullet points to use the additional width wisely. If I'm demonstrating software, a similar issue exists (unless it's software with lots of tool docks, like illustration software. The issue is that I'm still working with 7' of width, regardless of the ratio. With 16:9 (and other wide formats) that means my screen is much "shorter" than if I use 4:3 resolutions.
You note some good points in relation to your content and your level of knowledge, however my experience in general is that with new laptops and monitors being almost all widescreen formats, most presenters now tend to create content using those widescreen formats.  Adding to that, presentations seem to increaingly be incorporating other media that is sometimes in widescreen format.  And many of those same people do not know how to deal with extended desktops, changing the resolution for the second output, etc.
It seems that your situation may be a good example of one where your specific needs and knowledge suggest a different approach than what might work best for many others in similar situations.
Gerry Seymour
« Reply #6 on: January 28, 2013, 10:14:06 pm »
Jordan has addressed most of this for me, but I'll clarify on a few points.
I'll have some control of throw distance. In seminars of this sort, there's considerable flexibility up front, so off-angle (sideways) placements won't be an issue. Of course, keystoning is an issue in almost all situations, and pretty much all projectors do a reasonable job with this.
As for the dual-lamp offerings, I do like the concept of them, as this also (usually) means no downtime if a lamp goes out. However, I've not yet come across one that was as portable and inexpensive as comparable single-lamp offerings. I'll likely resort to just carrying a spare lamp.
Noise level has never been much of an issue with any of the portable projectors I've encountered. I've even had to speak over some with failing fan motors - which about doubles the perceived noise level - without any real issue. As my wife can attest, I"m pretty loud. :)
As for other points, I actually covered many of them in my first two posts (type of material, 4:3 ratio, etc.). What I didn't cover was source format. Currently, every computer I'd likely use is capable of VGA (one of them via Displayport adapter), and those cables (and the Displayport adapters) are easy to find, so that's my preference. Of course, it would be nice if it had HDMI or other newer-format input, as well.
Gerry Seymour
Gerry Seymour
« Reply #7 on: January 28, 2013, 10:20:18 pm »
I understand those points, and that some of the adjustments I make are difficult for some. I still maintain that 4:3 is a more universally useful ratio for these situations (different in other situations). The fact is that the limiting factor is usually the width of the screen. Thus, widescreen material letterboxed into 4:3 will be exactly the same size it would be on a 16:9 presentation. The PowerPoint slides (and similar material), however, will be significantly larger in 4:3 than in widescreen formats.
Gerry Seymour
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #8 on: January 29, 2013, 01:17:17 am »
This is very useful to me.
I am also looking at projectors.
What I find hard to decipher is how to figure out what size image I can get at what distance. For example, determining if a particular unit will be suitable for
6' wide screen at 14' or
10' wide at 30'
I know I need 3000 to 4000 lumens for my applications.
Thanks
Brad Weber
  • Marietta, GA
« Reply #9 on: January 29, 2013, 07:12:35 am »
10' wide at 30'
Rob, most projector manuals are available online and most of those include a chart or calculation for throw distance and image size.  Many projector manufacturers also have some form of projection calculator on their web sites that where you enter certain pieces of information and it calculates the results, often showing some graphical representation of those results.  There is also http://www.projectorcentral.com/projection-calculator-pro.cfm that can calculate throw distances, image sizes and image brightness for most current and many discontinued projector models.
Pages: [1] 2 3  All   Go Up
