Author Topic: Homemade testers and other soldering projects  (Read 2558 times)
Randy Culpepper
« on: January 21, 2013, 11:07:25 pm »
What have you made? I'm interested in anything you may have soldered together yourself.
I've made my own Clear Com call light from a diagram I found online.
I'd love to be able to make a phantom power tester/noise generator.
Re: Homemade testers and other soldering projects
« Reply #1 on: January 22, 2013, 07:44:04 am »
I used to build all my own gear-mixing consoles-amplifiers-crossovers and so forth-but those can ge quite involved.
A quick dirty hand tester is a cable tester that uses series LED's with the wires.  real simple and quick and cheap.  It won't tell you if the cable is open or shorted-but will tell you if it is good or bad and is grat for findng intermittants.
A phantom power tester is real easy-just use 2 LOW CURRENT led's and series resistors from pins 2 and 3 to ground.
Now part of the problem is that phantom power is not always 48V (sometimes 24V or less)-so that needs to be taken into account for the resistor calculation.
Noise generators are easy-just Google noise generator and you will find all kinds of circuits.
Zachary Zimmerman
  • Shenandoah, VA USA
« Reply #2 on: February 03, 2013, 11:13:14 pm »
Found this on a search
http://blog.hardcore.lt/mic/archives/010942.html
Hey Y'all watch this
Page created in 0.022 seconds with 22 queries.
