Author Topic: Speaker Wiring Question  (Read 4072 times)
Joe Hicks
« on: December 24, 2012, 01:30:08 pm »
Is there a wiring method that I can use to keep three speakers at the same impedance? I see diagrams that show 4 speakers using the series/parallel method that stay at the same impedance but can that be done with three speakers.
Just some insight-- I'm wiring a cluster of three speakers above center stage and want to run all three speakers off of one amp in bridged mono mode (due to budget constraints)
Thanks!
Patrick Tracy
  • Boulder, CO, USA
    • Boulder Sound Guy
Re: Speaker Wiring Question
« Reply #1 on: December 24, 2012, 02:03:37 pm »
I'm pretty sure the math doesn't allow for that.
  • Old enough to know better
  • Audio Plumber
« Reply #2 on: December 24, 2012, 04:55:44 pm »
Thanks!
No, you can't run 3 speakers as anything but all parallel, or all series. You will probably better off running the outside 2 speakers in parallel on one channel, and the center speaker on the other channel, so you have some control between inside and outside.
Rickcperry
    • Pro Audio Development
« Reply #3 on: December 25, 2012, 02:26:50 pm »
Thanks!
You can run series/parallel with 3 speakers but the series speakers motor assembly will not perform as the parallel ones will. It's complicated to explain but I would simply rather leave the other speaker disconnected than to deal with the lack of performance from the lazy driver.
In car audio you usually see the woofers Parallel as to get the strongest motor assembly available for pumping bass.
On another side of the coin, if the cabs show 8 ohms each, you can parallel them to mono, but not BRIDGED mono. Just like putting 3 wedge monitors on one side of an amp. Everything works good until some wise guy comes along and bridges the amp. Then it's running at 1.3 ohms and by the end of the night, you could fry an egg on the amp. IF it makes it to the end of the night.
Rick
I cannot teach you how to mix, I can only show you how to use the equipment...
www.rickcperry.com
Joe Hicks
« Reply #4 on: December 26, 2012, 01:12:39 pm »
Great idea-- I will probably go this way. But... what does the unequal load (4ohms one channel/8ohms the other) do to my amp? Can it handle it? I'm probably gonna use the QSC RMX series amp (probably a question for the amp manufacturer?)
  • Audio Plumber
« Reply #5 on: December 26, 2012, 01:37:21 pm »
It is not a problem for the amp at all. Unequal loads are fine.
g'bye, Dick Rees
  • Duluth
« Reply #6 on: December 26, 2012, 01:37:39 pm »
No worries.
Joe Hicks
« Reply #7 on: December 26, 2012, 03:47:01 pm »
Great. Thanks guys.
Steve Milner
    • DcSoundOp Audio Blog
« Reply #8 on: December 26, 2012, 03:57:57 pm »
Peavey to the rescue...  ;D
Here is Marty McCann's article from 1995 that covers running three center clustered speakers from a single bridged amplifier to cover both near and far-fields. I have a hard copy of this somewhere around here, but apparently someone smart decided to put Marty's old papers onto the inter-webs.
http://www.peavey.com/support/technotes/soundsystems/bridgemode.cfm
Enjoy.
Steve Milner
« Reply #9 on: December 26, 2012, 04:01:51 pm »
And Marty's drawing that is included in the article, for those who prefer brevity.
