Author Topic: Erratic LED flickering issue  (Read 8395 times)
Bill Hinds
Re: Erratic LED flickering issue
« Reply #10 on: December 03, 2012, 07:19:24 pm »
I had a similar problem with Chauvet LED PAR Tri-B fixtures several weeks after the initial install. Turned out one fixture went bad (was replaced under warranty). Thankfully there were only 7 fixtures in the chain but drove everyone crazy for a while as it was in the middle.
How did you determine it was bad? Remove it from the DMX chain?
Bill Hinds
« Reply #11 on: December 03, 2012, 07:32:50 pm »
Well, today I go to continue with the trouble shooting process and guess what? No flickering!  Tried everything to make it flicker but no luck. So, I guess I will wait for it to start back up again as I know it did not just fix itself.
Bill Hinds
« Reply #12 on: December 03, 2012, 07:36:52 pm »
Ok, here is a question.  Can a conventional dimmer cause noise onto the ground and create interference by getting into pin one on the DMX chain?  If so, what would could cause the dimmer to do this? I am starting to think this may be an electrical issue.
« Last Edit: December 03, 2012, 07:41:03 pm by Bill Hinds »
Scott Hofmann
« Reply #13 on: December 04, 2012, 10:25:16 am »
Yep, just plugged the Dmx in and out cables together and bypassed it.
Scott Hofmann
Scott Hofmann
« Reply #14 on: December 04, 2012, 10:29:16 am »
Not likely the dimmer would electrically affect it but you might try checking the AC feed for proper hot/neut/gnd condition and/or feeding AC from a different source to the LED's. Stranger things have happened.
Scott Hofmann
Josh Daws
« Reply #15 on: December 10, 2012, 11:08:20 pm »
this is very possible. i came across an issue in a bar where there was a small voltage running across the building ground and was wreaking a lot of havoc. my fix was a DMX splitter, more specifically the DMX Splitter 4 from microh (they also have a rackmount model). these specifically isolate the DMX ground from the building ground, both isolating and boosting the DMX signal. whilst also allowing you to split out 4 DMX chains per universe.
Brett Gilbert
    • Facebook
« Reply #16 on: December 17, 2012, 10:52:06 pm »
DMX optical isolators are always a good thing to have around to fix ground loop issues.  Also, some low-end LED fixtures are very very finicky about the DMX refresh rate.  I use Chauvet TRI-B fixtures and I'm really happy with them but initially I had issues with occasional flickers and flashes. I bought a Doug Fleenor DMX timing regenerator and they're flawless now.  Also, as a side benefit if the console goes down it will hold the last frame of DMX data that was active so you're not left in the dark.
Brett Gilbert
Page created in 0.068 seconds with 23 queries.
