Author Topic: Multiple antennas + WL mics  (Read 7077 times)
Kellen Tyburski
    • Kellen Tyburski | Audio Engineering
« on: November 18, 2012, 10:35:48 am »
Hey all,
I have a gig tomorrow with 16 Wireless Shure UHF-R's, and I am brainstorming on the Best Practice for setting up my antenna's.
The racks I will be using are broken up into (2) 10 Packs, each with a UA845 antenna distro. 12 of these mics will be scattered throughout the audience, and 4 will be used as stage mics for talking heads. The Antenna's are the full range uni-directional "shark fins"...
I'm considering 2 options:
1.) Using 4 antennas (2 from each separate DA) as 2 independent systems....but I hesitate to just put all 4 of them on sticks in a line, or in pairs.
2.) Using 2 antennas only and daisy chaining the 2 DA's. I can eliminate 1 dual receiver from the first rack of 10, and use my 2 free DA outputs to hop to the DA in rack #2. This leaves me with 18 total receiver's, which is 2 more than I need.
Curious what you would do, and if either option is a "no-no" and why. I am doing some presetting today so any quick tips would be MUCH appreciated...
Thanks for any help!!
Kellen
KT
  • Old enough to know better
  • Audio Plumber
Re: Multiple antennas + WL mics
« Reply #1 on: November 18, 2012, 11:03:23 am »
Hey all,
Kellen
If the setup is in a wide room, like the Conrad, you may want to use 4 antennas and keep the stage mics and the center of house Q&A mics in 1 rack with the antennas aimed at the stage, and the wide Q&A mics in the other rack with the antennas aimed out toward the ends of the room. You lose much of the advantage of diversity, but may gain better coverage.
If it is a deep ballroom, like the Marquis, either way should be fine.
In either case, I hope both racks are not the same band split. You will have a hard time getting 16 J5s to work in one place, particularly the Marriot Marquis. ;-)
Kellen Tyburski
« Reply #2 on: November 18, 2012, 11:21:55 am »
Hey Mac, thanks for the quick response...
All 20 are all on the H4 band. I'm thinking it would be better to go grab some loose dual units and just stack em to make the other 6, all on a different band than H4. Now that I hear that using the 4 antenna's is do-able, I'll try sectioning off the room into 2 chunks and use 1 DA per chunk, pointing the antennas in that direction like you said.
KT
  • Audio Plumber
« Reply #3 on: November 18, 2012, 11:29:35 am »
Sorry. If these are rented, you need to make sure not to get that many units in the same bandsplit in the future. Finding good frequencies would be easier with 10 J5s and 10 H4s, or better yet 3 bandsplits. With multiple bandsplits you do have to do your own frequency coordination because you can't rely on the manufacturer's groups, but that is the price of doing business with 20 RF mics. You can use WWB, or IAS (or others) to do the coord.
Kellen Tyburski
« Reply #4 on: November 18, 2012, 12:04:25 pm »
Nope, they are not rented. When I went back to go find some loose dual units there were about 16 more singles on the H4 band. I guess whoever purchased them did not know, or was not thinking straight! I found 4 on J5, and a dual unit on the L3 band so I should be set. I will probably use those for the stage mics to keep them separate. I am going to sit down with WWB 6 today and give it a go!
« Last Edit: November 18, 2012, 12:05:57 pm by Kellen Tyburski »
KT
Henry Cohen
  • Westchester Co., NY, USA
« Reply #5 on: November 18, 2012, 05:35:35 pm »
Another option, if the room isn't terribly deep AND wide, and this is merely a talking head event with a backdrop or projection screen about mid-stage, is to place two directional antennas directly behind the backdrop just on stage left and right and cross aim them to the diagonal corners at the back of the house.
Position above [talking] head level and give a slight downtilt.
Henry Cohen
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #6 on: November 18, 2012, 11:12:51 pm »
Which is exactly what I used to do.  Nice to see a real pro actually confirm the validity of my approach.
brian maddox
bdmaudio@gmail.com
Patrick Moore
« Reply #7 on: November 19, 2012, 01:19:23 am »
Yes, same here.  Put them on desks stands and hide them behind the fast fold screen skirt.  Works really well and is virtually invisible.  :)
  • Audio Plumber
« Reply #8 on: November 19, 2012, 10:42:45 am »
Unless of course the mic receivers are at FOH. He didn't say so specifically, but my guess is that in Kellen's case they are.
Kellen Tyburski
« Reply #9 on: November 19, 2012, 09:31:04 pm »
Correct, my receiver's were @ FOH. In this case having the antenna's behind the stage might not have been ideal, but I will definitely consider that in the future. I ended up using something along the lines of Mac's first suggestion, which worked perfectly.
I used WWB6 for the first time and it worked really well.. I didn't have any trouble finding clean frequencies on 10 H4's, 4 J5's, and 2 L3's.
The gig went really well, thanks for the tips guys...
KT
KT
Page created in 0.05 seconds with 23 queries.
