I use the 1818 for live. It's nice because I don't need a snake. The big down side is the gains are on the box . I don't have an Ipad anymore so I use VNC on my iphone to connect to my laptop running VSL with screen sharing enabled in os. If the gains were motorized and you could control remotely that would be amazing. I plan on getting a 1u rack mount computer to run VSL and a 8x8 AD/DA adat unit to get those extra inputs. I do like the presets you can drag on to the channel and that you can define your own.
-Matt
I have a question, does the ipad use also require the use of VNC? I'd like to hear more about this 1u pc you get for the rack. Sounds like a nice setup, especially when you have 16 channels. Can another 1818 be used for the other 8 channels?
Also, can the unit be configured completely from the front panel, or only with PC software? I would be a little concerned if PC down for any reason, unable to use as mixer?
