Another audio forum I frequent, is in yet another childish scuffle, arguing if "throw" exists, despite being provided with several links from eminent entities stating it's use.
http://www.voidaudio.com/news/news_item.asp?NewsID=33- Stasys Series
Designed as a point-source touring system for medium-sized venues to the largest-scale stadium events, this series is also proving popular in club installations worldwide. It comprises the Stasys 3 V2 mid-high enclosure, incorporating Void’s unique Waveformer technology, and the Stasys 4 foldback monitor, which is also designed for FOH deployment in smaller venues. These units are complemented by the Stasys 8 horn-loaded sub, and the Stasys X wide-band horn-loaded sub, which uses five resonant chambers, extending the response down to 35Hz, and maximising both efficiency and long-throw projection.
http://www.prosoundweb.com/article/das_audio_deployed_at_stadio_atleti_azzurri_ditalia/“This situation necessitated loudspeakers that had long throw characteristics capable of reaching the people sitting in the end-zone and goal area grandstands—while being lightweight so as to conform to building codes.”
http://www.meyersound.com/products/concertseries/msl-4/"The Meyer Sound MSL-4 is a high-Q, arrayable loudspeaker designed for a wide variety of medium- to long-throw applications. The MSL-4’s tightly defined coverage pattern allows seamless integration into array clusters, which may be tight-packed for long throw or splayed for broader coverage. "
http://www.turbosound.com/cgi-bin/turbo_coranto/viewnews.cgi?id=EFupkyZVFErOTDcDta&style=print_news&tmpl=print_news"To provide mids and highs, Landry selected Turbosound Aspect Series speakers. Six TA-880H speakers provide the long throw to the far ends of the arena, while three TA-550H models handle the midrange throw to the near sides. Three more TA-500HM speakers are hung below for short throw and floor coverage. The area behind and below the cluster is covered by a set of Turbosound TCS-59s as rear fills augmented by TCS-40s for downfill."
http://www.funktion-one.com/products/resolution-5-skeletal/Overview:
"The Resolution 5S is a three-way, long throw loudspeaker enclosure designed to operate from 100Hz upwards."
http://nexo-sa.com/en/articles/1055/nexo-renews-its-residency-at-gentings-arena-of-stars/"Sub-woofers placed at ground level under the main cluster were configured as left and right with 12 units of the NEXO 18” RAYSUB 18PT controlled by a NEXO NX242-ES4 processor The Ray Subs provide high sound pressure level output and offer long-throw even coverage. All audio signal is managed by an XTA DP 448 system. An existing Midas Heritage 4000 was used for FOH mixing whereas a new Yamaha PM5D was purchased for monitoring that was supported by a NEXO NX-Y16ES 16 channel Ethersound digital interface. The managing and controlling of the Ethersound network was done by an Auvitran AVE-Es monitor system."
http://www.electrovoice.com/product.php?id=14Xvls
Three-way, long-throw element
High-output, three-way line-array system
Rectangular cabinet design
90º horizontal coverage pattern ideal for long-throw applications
EV Hydra(R) time-synchronized vertical plane-wave generator provides excellent far-field summing
Ring Mode Decoupling (RMD™) provides level-independent fidelity,
greater midbass clarity, and high-frequency accuracy
Proprietary rigging allows for rapid venue load-in and load-out
http://www.martin-audio.com/products/datasheets/W8LLongbowdatasheet.pdfSince the launch of the W8L, Martin Audio has developed a patent pending technology, which provides an
exceptional degree of control over the curvature of the high frequency vertical wavefront. Our research has shown
that even very long throw systems benefit from a small but specific amount of wavefront curvature. By coupling this
technology with significant advances in high frequency device design we have created a quad-driver, high frequency
system with the very high efficiency of 119dB (1W/1m). This allows the W8L Longbow to cope with the most
adverse atmospheric conditions which can severely attenuate high frequencies over long distances. The new high
frequency system also results in improved HF summation of cabinets in the array and a corresponding reduction of
side lobes.
http://www.audioprointernational.com/news/read/das-audio-reinforces-stjarnan-fc-stadium/04934Þorsteinn Halldórsson, the firm’s owner, said: “As most events of this nature cater to crowds of about 2,500 people we elected to install four of DAS Audio’s DR-12 2-way, full-range loudspeakers along with two BiDriver Plus systems, which are two-way, mid-high units designed for long throw applications. A D.A.S Audio DSP-26 stero/mono processor handles loudspeaker management duties and DAS PS-1400 stereo power amplifiers drive the speakers.”
Comments from the pros ?
