Author Topic: Using RG6 Quad for line level signal to RCA fed subwoofer  (Read 17651 times)
Jeff Heart
« on: August 09, 2012, 02:17:37 pm »
This goes against everything I thought I was educated with in reference to proper signal lines.  We are doing a residential install where a high end sub woofer is going to be placed pretty far from the head-end.  It only has RCA inputs.  One of my guys who is a seasoned vet in residential install is telling me to use RG6/u quad shield cable terminated with RCA's for the long run of about 80 feet.  Stating that the shield will help with any EMI.  Can you use RG6 coax cable for this purpose???  I was thinking more on the lines of using an audio balun via cat5e but he doesn't want the need for baluns hanging around behind the sub or rack.  I get one shot at this install because once the walls are sealer up, his particular home will cost a small fortune to re-do the line.
   Unless I am failing to maintain my knowledge through the years, or something has changed since the last time I read up on cable types, 75 Ohm RG6 CATV cable is entirely incorrect to run a line level audio signal.
thanks for answers in advance,
Jeff
Jeff Heart
Re: Using RG6 Quad for line level signal to RCA fed subwoofer
« Reply #1 on: August 09, 2012, 02:20:05 pm »
Also, he said he has done it a million times and always works for him which is why he is making me second guess myself.  Is he just getting lucky on his installs?
Hal Bissinger/COMSYSTEC
    • COMSYSTEC
« Reply #2 on: August 09, 2012, 04:56:21 pm »
If you want to convert it to a balanced line go ahead (but I wouldn't use CAT5 and those cheap baluns which really aren't baluns. That I would worry about.) For 80 feet RG-6 should work fine. All it will be is an unbalanced shielded line. Since this is for a sub you wouldn't even have to worry about HF rolloff. Note that they also make compression RCA connectors for RG-6.
-Hal
John Livings
  • Los Angeles, California
« Reply #3 on: August 10, 2012, 12:08:05 am »
Hi Jeff,
Consider running a piece of 1 inch or 1 1/4 inch plastic conduit to the attic/crawl space if there is one.
Also, if the RG-6 has "F" connectors already installed, Just buy 2- female F connector X RCA female connectors (one for each end).
Sometimes a standard F  or RCA connector may not fit the "Quad" cable, Larger ones are made for that cable.
Or just buy 100 feet already made up with F ends already installed.
Regards,  John
Ryan C. Davis
  • SL,UT
« Reply #4 on: August 10, 2012, 12:56:42 am »
Jeff,
You are just fine with RG6 but I wouldn't waste my time with quad, really hate working with that stuff. It may offer some additional EMI rejection but we've always done fine with regular old RG6. Usually for subs we run RG59-SD which has 95% braiding opposed to the 65% braiding you'll see on standard RG6 or RG59.
To answer your question, your installer isn't misleading you, you're in good shape.
Ryan Davis
Tim Padrick
  • Indianapolis
    • T.P. Audio
« Reply #5 on: August 10, 2012, 02:40:59 am »
I'm thinking that what you may have a problem with is ground loop hum.  This is where running a balanced line with a transformer at one or both ends (consult Jensen Transformer) will save you.
Jeff Heart
« Reply #6 on: August 10, 2012, 11:44:01 am »
Thanks for the input.  I have all the connectors for whatever route we take.  I'm thinking I will end up running the RG6 AND a cat 5.  THat way, if one doesn't do the job, I have the alternate choice .  The client wanted it ran through the baseboard but I will try and get him to use conduit instead, if the architect's design will allow for that.
I have actually always had great luck with the cat5 and baluns but I also heard someone else mention that "not really a balun" comment.  Exactly what is not really a balun about those devices?  I usually use the Intelix one :  http://www.intelix.com/media/data_sheets/AVO_A2_TechSpecs.pdf
I never got into exactly what it does inside but does it just merely adapt to rj45 without truly balancing the signal?  Is that the difference between these passive cheapy baluns vs the failry expensive "true balun" powered ones?
    • COMSYSTEC
« Reply #7 on: August 13, 2012, 12:33:51 am »
A "balun" is either a transformer or an active powered device that converts an unbalanced line to two wire balanced or vice versa. Those Intelix units appear to utilize a couple of transformers in each unit. There are other manufacturers (particularly of wall jacks) that do nothing more than connect the unbalanced input to a pair on the CAT5.
The term balun actually refers to an RF transformer that serves the same function. The old 300 ohm to 75 ohm coax adapters that used to be used on the back of TVs or antennas is the best example. Personally I don't like that "balun" is now being used as a catch all name to describe anything that allows something to be carried over CAT5. "Converter", "adaptor" or "matching transformer" would be more accurate as the case permits but I guess "balun" is the dumbing down of the term for today's techie types.
I would also take issue with using CAT5. I would much rather see a shielded audio cable. Here too, CAT5 seems to have become the standard all-purpose low voltage wire for lazy people. You see it used for anything from doorbells to thermostats to telephone. If you are going to go through the trouble of running audio wire I would use audio wire. While a twisted pair of a CAT5 cable provides decent noise rejection you can't go wrong by having the added insurance of a shield which is standard practice.
This does mean that you will have to make another choice for your matching transformers but it should probably work out cheaper because you only need a single transformer on each end. Those Intelix units are 2 channel with two transformers in each housing and with an 8 pin/8 position jack for the CAT5.
-Hal
  • Old enough to know better
  • Audio Plumber
Baluns
« Reply #8 on: August 13, 2012, 10:49:15 am »
Thank you.
duane massey
« Reply #9 on: August 13, 2012, 12:37:51 pm »
I'd run one shielded pair, #22. Don't use transformers unless you need to. Try it without first, probably work fine. RG6 would work, but stiffer, harder to work with. Don't see the point of using Cat5 unless you're running multiple signals.
Duane Massey
Houston, Texas
Page created in 0.018 seconds with 18 queries.
