Pages: 1 2 [3]  All   Go Down
Author Topic: My first sub alignment using Smaart  (Read 15632 times)
Mark McFarlane
  • Middle East
    • Arkose Records
Re: My first sub alignment using Smaart
« Reply #20 on: August 06, 2012, 03:14:23 pm »
Mark, I view the first plot as a meaningless measurement, not ambient noise....
As it turns out, my ambient noise plot really isn't that bad. I certainly wouldn't recommend someone using a transfer function instead of a spectrum plot, but since my reference trace was in this case esentially random electronic digitl console noise, the transfer fuctions magnitude plot itself isn't that far from a single channel spectrum plot.
The trick here is that my refernce trace was essentially white.
Below is a comparison of using atransfer function versus a spectrum plot for measuring the ambient noise in my garage.  The major events, like the fan noise at 56Hz, are basically the same on both plots.
One can try this experiment at home.
Again, I don't recomend using the transfer function to measure what should be a single channel spectrum measurement, but if your reference trace is low level white-ish noise the results won't be too far off, the math works fine.
Anyway, back on track, anyone have a comment on the system alignment?
Mark McFarlane
ARKOSERECORDS
Turn down what's too loud.
Paul Tucci
« Reply #21 on: August 06, 2012, 09:51:26 pm »
Mark,
As I stated previously, I don't recommend using a TF measurement for what is a single channel measurement either, but if you do, I highly recommend using the Magnitude Threshold parameter option during a TF measurement so that no resultant display is given if there is no valid Reference signal. Proper technique trumps blind luck in this endeavor.  I trust that was illustrated by the previous posts.
Paul
Rasmus Rosenberg
« Reply #22 on: August 09, 2012, 06:42:04 am »
Mark,
Paul
Paul,
When you have time it would be nice with a post about background noise and how to measure it and how to relate to it (how to try to exclude/include it from measurement etc). If Dough would chime in with the Systune feature it would be nice too. There seems to pop up quite a few questions about it. Where people hired to look at a speaker installation also gets tasked to analyze background noise/ fan noise etc. But most importantly proberly how to measure and and relate to how much a venue "spills" to its neighbours out side, upside, downside etc. I know a big task with a can of worms, but im sure you and others know how to do it, or at least has a priotity list :)
Doug Fowler
  • Saint Louis, MO USA
« Reply #23 on: August 10, 2012, 10:03:00 pm »
Paul,
SSA Filter demonstration video:
http://www.youtube.com/watch?v=UiEZ7lnShrA&feature=youtube_gdata_player
Pages: 1 2 [3]  All   Go Up
Page created in 0.056 seconds with 23 queries.
