Author Topic: Types of podiums?  (Read 7359 times)
Matt Collins
Re: Types of podiums?
« Reply #10 on: August 01, 2012, 12:01:25 am »
i've even seen some with built in RGB LED edge lighting that's dmx controllable...now those are fancy!
Pics?
James Feenstra
« Reply #11 on: August 01, 2012, 08:41:16 pm »
Pics?
they're a custom build...basically it's a standard acrylic lectern with some modifications. namely LED strip lighting down the edges of the front facing with the control box hidden in the base
the ones i've seen weren't entirely acrylic, they're an acrylic/polished metal hybrid, as you need to hide the sides/back. They look incredibly cool, especially when the company logo is etched into the acrylic front panel, as it lights up with the LEDs
as for actual cost, I have no idea.
you could even make a generic frame with a removable acrylic piece and do custom panels for clients.
Elevation Audiovisual
www.elevationav.com
Taking your events to the next level
Jordan Wolf
« Reply #12 on: August 05, 2012, 10:50:04 am »
Let's see your preferences on podiums?
Transparent, thin, big and bulky, etc  8)
If you go for wood, make sure it's actual wood, not particle board.  They get decimated when handled roughly (unfortunately, that's what we have at my job).  Anything with a laminate will eventually get gouged or knicked and we be useless.  Cabinet-grade multi-ply birch (like that used to build loudspeaker cabinets) is pricey, but well worth the cost in the long run.
Lucite/Acrylic lecterns are nice, but should only be handled with cotton gloves, so as to avoid fingerprints.
My job has some video lecterns - 32" wide (minimum) with a plasma oriented vertically in the front of it.  You attach or upload an image and that becomes the client's logo/frame capture.  If you're savvy, you can change the display with the mood the client wants for the room. ;-)
Truss lecterns are popular…they're nice if you have any structurally unsound pieces lying around.  Just get them cut (or do it yourself) to a standard height (?) and add a top piece.  They probably even come as "make your own" nowadays.  They look really nice with a truss sock/condom and warmer (internal uplight).
Personally, I prefer the lecterns that the presenter can't hide behind.  They are fairly skinny and only require some judicious use of gaff tape to conceal the wires going to/from.
If you have no say in your podium du jour, then you should get some mic mounts that allow you to do what you need to with your mic(s) of choice.
Jordan Wolf
Scott Hofmann
« Reply #13 on: August 27, 2012, 06:07:16 pm »
After examining this lectern at Infocomm, I would never again buy a particle board or a wood lectern:
http://www.summitlectern.com/
They use them at a local military base for outdoor ceremonies as well.
Scott Hofmann
Pete Erskine
    • Best Audio
« Reply #14 on: August 28, 2012, 10:27:23 am »
You mean lecterns?????
I was always an firm believer in calling them Lecterns, not Podiums.  However most dictionaries now define Podium as a Lectern so now we can all just go with the flow.
Pete Erskine
917-750-1134
www.bestaudio.com
peter@bestaudio.com
Steve Kennedy-Williams
    • Kennedy-Williams.net
« Reply #15 on: August 28, 2012, 06:46:08 pm »
came here for this. thanks.
Page created in 0.065 seconds with 24 queries.
